2nd Law of Thermodynamics
Two classical statements of the Second Law of Thermodynamics:
Kelvin & Planck
"No (heat) engine whose working fluid undergoes a cycle can absorb heat from a single reservoir, deliver an equivalent amount of work, and deliver no other effect"
Clausius
"No machine whose working fluid undergoes a cycle can absorb heat from one system, reject heat to another system and produce no other effect"
Both statements of the Second Law constrains the First Law of Thermodynamics by identifying that energy goes downhill. The Second Law is concerned with Entropy (S) which is produced by all processes and associated with the loss of ability to do work. The Second Law states that the entropy of the universe increases.
For energy to be available there must be a region with high energy level and a region with low energy level. Useful work must be derived from the energy that flows from the high level to the low level.
  • 100% energy can not be transformed to work
  • entropy can be produced but never destroyed
Efficiency of a heat machine
The thermodynamic efficiency of a heat machine working between two energy levels is defined in terms of absolute temperature and can be expressed as
η = (Th - Tc) / Th = 1 - Tc / T                                                 (1)
η = efficiency
Th = temperature high level (K)
Tc = temperature low level (K)
As a consequence, to attain maximum efficiency - Tc has to be as cold as possible. For 100% efficiency Tc should equals to 0 K. This is in real life impossible so the efficiency will always be less than 1 (100%).
Change in entropy > 0
irreversible
process
Change in entropy = 0
reversible
process
Change in entropy < 0
impossible
process
Entropy is used to define the unavailable energy in a system and entropy defines the relative ability of one system to act on an other. As energy moves toward lower energy levels where one is less able to act upon the surroundings, the entropy is said to increase.
  • For the universe as a whole - the entropy is increasing
  • Entropy is not conserved like energy
Go to Thermodyamics key values internationally agreed, Standard state and enthalpy of formation, Gibbs free energy of formation, entropy and heat capacity and Standard enthalpy of formation,  Gibbs energy of formation, entropy and molar heat capacity of organic substances for listing of values for a lot of inorganic and organic substances.
Thermodynamic Entropy
Change of entropy in a thermodynamic system can be expressed as
dS = dH / Ta                             (2)
dS = change in entropy (kJ/kg K)
dH = change in enthalpy or internal energy (kJ/kg K)
Ta = average temperature (K)
Carnot Heat Cycle
In a heat engine, a gas is reversibly heated and then cooled. A model of the cycle is as follows: State 1 --(isothermal expansion) --> State 2 --(adiabatic expansion) --> State 3 --(isothermal compression) --> State 4 --(adiabatic compression) --> State 1
State 1 to State 2: Isothermal Expansion
Isothermal expansion occurs at a high temperature Th, dT = 0 and dE1 = 0. Since dE = H + w, w1 = - H1. For ideal gases, dE is dependent on temperature only.
State 2 to State 3: Adiabatic Expansion
The gas is cooled from the high temperature, Th, to the low temperature, Tc. dE2 = w2 and H2 = 0 (adiabatic).
State 3 to State 4: Isothermal Compression
This is the reverse of the process between states 1 and 2. The gas is compressed at Tc. dT = 0 and dE3 = 0. w3 = - H3
State 4 to State 1: Adiabatic Compression
This is the reverse of the process between states 2 and 3. dE4 = w4 and H4 = 0 (adiabatic).
The processes in the Carnot cycle can be graphed as the pressure vs. the volume. The area enclosed in the curve is then the work for the Carnot cycle because w = - integral (P dV). Since this is a cycle, dE overall equals 0. Therefore,
-w = H = H1 + H2 + H3 + H4
If you decrease Tc, then the quantity -w gets larger in magnitude.
if -w > 0 then H > 0 and the system, the heat engine, does work on the surroundings.
The sum of (dH / T) values for each step in the Carnot cycle equals 0. This only happens because for every positive H there is a countering negative H, overall.
Example - Entropy Heating Water
A process raises 1 kg of water from 0 to 100 oC (273 to 373 K) under atmospheric conditions.
Specific enthalpy at 0 oC (hf) = 0 kJ/kg (from steam tables) (Specific - per unit mass)
Specific enthalpy of water at 100 oC (hf) = 419 kJ/kg (from steam tables)
Change in specific entropy:
dS = dH / Ta
    = ((419 kJ/kg) - (0 kJ/kg)) / (((273 K) + (373 K)) / 2)
    = 1.297 kJ/kgK
Example - Entropy Evaporation Water to Steam
A process changes 1 kg of water at 100 oC (373 K) to saturated steam at 100 oC (373 K) under atmospheric conditions.
Specific enthalpy of steam at 100 oC (373 K) before evaporating = 418 kJ/kg (from steam tables)
Specific enthalpy of steam at 100 oC (373 K) after evaporating = 2675 kJ/kg (from steam tables)
dS = dH / Ta
    = ((2675 kJ/kg) - (418 kJ/kg)) / (((373 K) + (373 K)) / 2)
    = 6.054 kJ/kgK
The total change in specific entropy from water at 100 oC to saturated steam at 100 oC is the sum of the change in specific entropy for the water, plus the change of specific entropy for the steam.
Example - Entropy Superheated Steam
A process superheats 1 kg of saturated steam at atmospheric pressure to 150 oC (423 K).
Specific total enthalpy of steam at 100 oC (373 K) = 2675 kJ/kg (from steam tables)
Specific total enthalpy of superheated steam at 150 oC (423 K) = 2777 kJ/kg (from steam tables)
dS = dH / Ta
    = ((2777 kJ/kg) - (2675 kJ/kg)) / (((423 K) + (373 K)) / 2)
    = 0.256 kJ/kgK
Thermodynamics
1st Law of Thermodynamics
Adiabatic Flame Temperatures
Adiabatic flame temperatures for hydrogen, methane, propane and octane - in Kelvin.
Carnot Cycle Efficiency
Combustion Heat
Compressible Gas Flow - Entropy
Calculating the entropy in a compressible gas flow.
Efficiency
Efficiency is the ratio useful energy output to energy input.
Equilibrium
The mechanical, thermal, electrostatic, phase or chemical states of equilibrium.
Standard State and Enthalpy of Formation, Gibbs Free Energy of Formation, Entropy and Heat Capacity
Definition and explanation of the terms standard state and standard enthalpy of formation, with listing of values for standard enthalpy and Gibbs free energy of formation, as well as standard entropy and molar heat capacity, of 370 inorganic compounds.
Standardized Enthalpies and Entropies
Standardized enthalpies and entropies for some common substances.
Steam Entropy
Basic steam thermodynamics - entropy diagram.
Superheated Steam - Enthalpy
Enthalpy of steam superheated to temperatures above it's boiling point.
Superheated Steam - Entropy
The entropy of steam superheated to temperatures above saturation points.
Symbols Used to Denote a Chemical Reactions and Process or Condition
Explanation of symbols used as subscripts or superscripts to tell more about the type of chemical reaction, process or condition.
Thermodynamic Key Values Internationally Agreed
Internationally agreed, internally consistent, values for the thermodynamic properties (standard enthalpy of formation, entropy and [H°(298)-H°(0)]) of key chemical substances.
Thermodynamic Terms - Functions and Relations
Third Law of Thermodynamics
The entropy of a substance is zero if the absolute temperature is zero.
WABT - Weighted Average Bed Temperature
Definition and examples of calculation of weighted average bed temperature in adiabatic reactors.
Water-Steam Mollier Diagram
Wet Steam - Enthalpy
Zeroth Law of Temperature
The direction of heat flow.
