Thermodynamics of steam and condensate systems.
Entropy and disorder.
Saturated Steam Table with properties like boiling point, specific volume, density, specific enthalpy, specific heat and latent heat of vaporization.
Definition and explanation of the terms standard state and standard enthalpy of formation, with listing of values for standard enthalpy and Gibbs free energy of formation, as well as standard entropy and molar heat capacity, of 370 inorganic compounds.
An enthalpy and entropy chart for steam
Vapor and steam enthalpy, specific enthalpy of saturated liquid, saturated vapor and superheated vapor.
The entropy of steam superheated to temperatures above saturation points.
Internationally agreed, internally consistent, values for the thermodynamic properties (standard enthalpy of formation, entropy and [H°(298)-H°(0)]) of key chemical substances.
Introduction and definition of steam quality and dryness fraction including calculating wet steam enthalpy and specific volume.
