If saturated steam is exposed to a surface with a higher temperature the temperature of the steam will increase above the evaporating temperature. The steam is then described as superheated by the temperature degrees above saturation temperature.
Superheated steam is produced by passing saturated steam through an additional heat exchanger.
Superheated steam is also called
Thermodynamics of steam and condensate systems.
Entropy and disorder.
Calculating the entropy in a compressible gas flow.
Saturated Steam Table with properties like boiling point, specific volume, density, specific enthalpy, specific heat and latent heat of vaporization.
Standardized enthalpies and entropies for some common substances.
Absolute viscosity of steam at pressure ranging 1 - 10000 psia.
Vapor and steam enthalpy, specific enthalpy of saturated liquid, saturated vapor and superheated vapor.
Basic steam thermodynamics - entropy diagram.
Enthalpy of steam superheated to temperatures above it's boiling point.
An introduction to vapor and steam.
