Steam - Viscosity vs. Pressure
The absolute (or dynamic) viscosity of steam at pressure ranging 1 - 10000 psia can be found in the table below:
For full table with higher pressures - rotate the screen!
Temperature (oF) | Dynamic Viscosity - μ - (centiPoise) | |||||||||||||
Absolute pressure - p - (psia) | ||||||||||||||
1 | 2 | 5 | 10 | 20 | 50 | 100 | 200 | 500 | 1000 | 2000 | 5000 | 7500 | 10000 | |
Saturated Water | 0.667 | 0.524 | 0.388 | 0.313 | 0.255 | 0.197 | 0.164 | 0.138 | 0.111 | 0.094 | 0.078 | - | - | - |
Saturated Steam | 0.010 | 0.010 | 0.011 | 0.012 | 0.012 | 0.013 | 0.014 | 0.015 | 0.017 | 0.019 | 0.023 | - | - | - |
1500 | 0.041 | 0.041 | 0.041 | 0.041 | 0.041 | 0.041 | 0.041 | 0.041 | 0.042 | 0.042 | 0.042 | 0.044 | 0.046 | 0.048 |
1450 | 0.040 | 0.040 | 0.040 | 0.040 | 0.040 | 0.040 | 0.040 | 0.040 | 0.040 | 0.041 | 0.041 | 0.043 | 0.045 | 0.047 |
1400 | 0.039 | 0.039 | 0.039 | 0.039 | 0.039 | 0.039 | 0.039 | 0.039 | 0.039 | 0.040 | 0.040 | 0.042 | 0.044 | 0.047 |
1350 | 0.038 | 0.038 | 0.038 | 0.038 | 0.038 | 0.038 | 0.038 | 0.038 | 0.038 | 0.038 | 0.039 | 0.041 | 0.044 | 0.047 |
1300 | 0.037 | 0.037 | 0.037 | 0.037 | 0.037 | 0.037 | 0.037 | 0.037 | 0.037 | 0.037 | 0.038 | 0.040 | 0.043 | 0.046 |
1250 | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 | 0.036 | 0.036 | 0.036 | 0.037 | 0.039 | 0.042 | 0.045 |
1200 | 0.034 | 0.034 | 0.034 | 0.034 | 0.034 | 0.034 | 0.034 | 0.034 | 0.035 | 0.035 | 0.036 | 0.038 | 0.041 | 0.045 |
1150 | 0.034 | 0.034 | 0.034 | 0.034 | 0.034 | 0.034 | 0.034 | 0.034 | 0.034 | 0.034 | 0.034 | 0.037 | 0.041 | 0.045 |
1100 | 0.032 | 0.032 | 0.032 | 0.032 | 0.032 | 0.032 | 0.032 | 0.032 | 0.033 | 0.033 | 0.034 | 0.037 | 0.040 | 0.045 |
1050 | 0.031 | 0.031 | 0.031 | 0.031 | 0.031 | 0.031 | 0.031 | 0.031 | 0.032 | 0.032 | 0.033 | 0.036 | 0.040 | 0.047 |
1000 | 0.030 | 0.030 | 0.030 | 0.030 | 0.030 | 0.030 | 0.030 | 0.030 | 0.030 | 0.031 | 0.032 | 0.035 | 0.041 | 0.049 |
950 | 0.029 | 0.029 | 0.029 | 0.029 | 0.029 | 0.029 | 0.029 | 0.029 | 0.029 | 0.030 | 0.031 | 0.035 | 0.042 | 0.052 |
900 | 0.028 | 0.028 | 0.028 | 0.028 | 0.028 | 0.028 | 0.028 | 0.028 | 0.028 | 0.028 | 0.029 | 0.035 | 0.045 | 0.057 |
850 | 0.026 | 0.026 | 0.026 | 0.026 | 0.026 | 0.026 | 0.027 | 0.027 | 0.027 | 0.027 | 0.028 | 0.035 | 0.052 | 0.064 |
800 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.026 | 0.026 | 0.027 | 0.040 | 0.062 | 0.071 |
750 | 0.024 | 0.024 | 0.024 | 0.024 | 0.024 | 0.024 | 0.024 | 0.024 | 0.025 | 0.025 | 0.026 | 0.057 | 0.071 | 0.078 |
700 | 0.023 | 0.023 | 0.023 | 0.023 | 0.023 | 0.023 | 0.023 | 0.023 | 0.023 | 0.024 | 0.026 | 0.071 | 0.079 | 0.085 |
650 | 0.022 | 0.022 | 0.022 | 0.022 | 0.022 | 0.022 | 0.022 | 0.022 | 0.023 | 0.023 | 0.023 | 0.082 | 0.088 | 0.092 |
600 | 0.021 | 0.021 | 0.021 | 0.021 | 0.021 | 0.021 | 0.021 | 0.021 | 0.021 | 0.021 | 0.087 | 0.091 | 0.096 | 0.101 |
550 | 0.020 | 0.020 | 0.020 | 0.020 | 0.020 | 0.020 | 0.020 | 0.020 | 0.020 | 0.019 | 0.095 | 0.101 | 0.105 | 0.109 |
500 | 0.019 | 0.019 | 0.019 | 0.019 | 0.019 | 0.019 | 0.019 | 0.018 | 0.018 | 0.103 | 0.105 | 0.111 | 0.114 | 0.119 |
450 | 0.018 | 0.018 | 0.018 | 0.018 | 0.017 | 0.017 | 0.017 | 0.017 | 0.115 | 0.116 | 0.118 | 0.123 | 0.127 | 0.131 |
400 | 0.016 | 0.016 | 0.016 | 0.016 | 0.016 | 0.016 | 0.016 | 0.016 | 0.131 | 0.132 | 0.134 | 0.138 | 0.143 | 0.147 |
350 | 0.015 | 0.015 | 0.015 | 0.015 | 0.015 | 0.015 | 0.015 | 0.152 | 0.153 | 0.154 | 0.155 | 0.160 | 0.164 | 0.168 |
300 | 0.014 | 0.014 | 0.014 | 0.014 | 0.014 | 0.014 | 0.182 | 0.183 | 0.183 | 0.184 | 0.185 | 0.190 | 0.194 | 0.198 |
250 | 0.013 | 0.013 | 0.013 | 0.013 | 0.013 | 0.228 | 0.228 | 0.228 | 0.228 | 0.229 | 0.231 | 0.235 | 0.238 | 0.242 |
200 | 0.012 | 0.012 | 0.012 | 0.012 | 0.300 | 0.300 | 0.300 | 0.300 | 0.301 | 0.301 | 0.303 | 0.306 | 0.310 | 0.313 |
150 | 0.011 | 0.011 | 0.427 | 0.427 | 0.427 | 0.427 | 0.427 | 0.427 | 0.427 | 0.428 | 0.429 | 0.431 | 0.434 | 0.437 |
100 | 0.680 | 0.680 | 0.680 | 0.680 | 0.680 | 0.680 | 0.680 | 0.680 | 0.680 | 0.680 | 0.680 | 0.681 | 0.682 | 0.683 |
50 | 1.299 | 1.299 | 1.299 | 1.299 | 1.299 | 1.299 | 1.299 | 1.299 | 1.299 | 1.299 | 1.296 | 1.289 | 1.284 | 1.279 |
32 | 1.753 | 1.753 | 1.753 | 1.753 | 1.753 | 1.753 | 1.753 | 1.752 | 1.751 | 1.753 | 1.745 | 1.733 | 1.723 | 1.713 |
- 1 cP (Centipoise) = 10-3 Pa s = 0.01 Poise = 1.020×10-4 kp s/m2 = 6.721×10-4 lb/(ft s) = 0.00100 (N s)/m2 = 0.01 gram/(cm sec) = 2.4191 lb/(ft hr)
- The critical point for water is 705.40 oF and 3206.2 psia (374 oC - 218 atm)- For pressure beyond this point the fluid is supercritical1).
- Blue - viscosity of water
1) Supercritical fluids are phases of substances at high pressures above their critical temperatures. Supercritical water is superheated steam under high pressure of more than 3206.2 psia (200 atm). Under these conditions supercritical water decomposes to many substances.
• Thermodynamics
• Viscosities
Gases - Dynamic Viscosities
Absolute (dynamic) viscosities of some common gases.
Liquids - Dynamic Viscosities
Absolute (dynamic) viscosity values for some common fluids.
Superheated Steam - Entropy
The entropy of steam superheated to temperatures above saturation points.
Viscosity Converter: Convert Between Dynamic & Kinematic Viscosity
Water - Absolute (Dynamic) Viscosity vs. Temperature and Pressure
Absolute viscosity for water in centipoises for temperatures between 32 - 200oF.
