Follow the links for definitions of the terms specific enthalpy and entropy .
The figures and tables below shows how water enthalpy and entropy changes with temperature (°C and °F) at water saturation pressure (which for practicle use, gives the same result as atmospheric pressure at temperatures < 100 °C (212 °F)).
See Water and Heavy Water - thermodynamic properties.
See also Water Boiling points at high pressure, Boiling points at vacuum pressure, Density, specific weight and thermal expansion coefficient, Dynamic and kinematic viscosity, Heat of vaporization, Ionization Constant, pKw , of normal and heavy water, Melting points at high pressure, Saturation pressure, Specific gravity, Specific heat (heat capacity) and Specific volume for online calculatores, and similar figures and tables as shown below.
Specific enthalpy and entropy for liquid water at saturation pressure at temperatures from 0 to 374 °C:
For full table with Entropy - rotate the screen!
| Temperature | Enthalpy, H | Entropy, S | |||||||
| (°C) | (kJ/kmol) | (kJ/kg) | (kWh/kg) | (kcal/kg) | (Btu(IT)/lb) | (kJ/(kmol K)) | (kJ/kgK) | (kWh/(kg K)) | (Btu(IT)/lbm *R) (kcal/(kg K)) |
| 0.01 | 0 | 0.000612 | 0.00000017 | 0.00015 | 0.00026 | 0.00000 | 0.00000 | 0.0000000 | 0.00000 |
| 10 | 757.1 | 42.021 | 0.01167 | 10.04 | 18.1 | 2.722 | 0.15109 | 0.0000420 | 0.03609 |
| 20 | 1511.8 | 83.914 | 0.02331 | 20.04 | 36.1 | 5.341 | 0.29648 | 0.0000824 | 0.07081 |
| 25 | 1888.6 | 104.83 | 0.02912 | 25.04 | 45.1 | 6.616 | 0.36722 | 0.000102 | 0.08771 |
| 30 | 2265.2 | 125.73 | 0.03493 | 30.03 | 54.1 | 7.868 | 0.43675 | 0.000121 | 0.10432 |
| 40 | 3018.2 | 167.53 | 0.04654 | 40.01 | 72.0 | 10.31 | 0.57240 | 0.000159 | 0.13672 |
| 50 | 3771.5 | 209.34 | 0.05815 | 50.00 | 90.0 | 12.68 | 0.70381 | 0.000196 | 0.16810 |
| 60 | 4525.3 | 251.18 | 0.06977 | 59.99 | 108.0 | 14.98 | 0.83129 | 0.000231 | 0.19855 |
| 70 | 5279.9 | 293.07 | 0.08141 | 70.00 | 126.0 | 17.21 | 0.95513 | 0.000265 | 0.22813 |
| 80 | 6035.5 | 335.01 | 0.09306 | 80.02 | 144.0 | 19.38 | 1.0756 | 0.000299 | 0.25690 |
| 90 | 6792.8 | 377.04 | 0.10473 | 90.05 | 162.1 | 21.49 | 1.1929 | 0.000331 | 0.28492 |
| 100 | 7551.8 | 419.17 | 0.11644 | 100.1 | 180.2 | 23.55 | 1.3072 | 0.000363 | 0.31222 |
| 110 | 8312.9 | 461.42 | 0.12817 | 110.2 | 198.4 | 25.56 | 1.4188 | 0.000394 | 0.33887 |
| 120 | 9076.6 | 503.81 | 0.13995 | 120.3 | 216.6 | 27.53 | 1.5279 | 0.000424 | 0.36493 |
| 140 | 10614 | 589.16 | 0.16366 | 140.7 | 253.3 | 31.33 | 1.7392 | 0.000483 | 0.41540 |
| 160 | 12169 | 675.47 | 0.18763 | 161.3 | 290.4 | 35.00 | 1.9426 | 0.000540 | 0.46398 |
| 180 | 13747 | 763.05 | 0.21196 | 182.3 | 328.1 | 38.54 | 2.1392 | 0.000594 | 0.51094 |
| 200 | 15354 | 852.27 | 0.23674 | 203.6 | 366.4 | 41.99 | 2.3305 | 0.000647 | 0.55663 |
| 220 | 17000 | 943.58 | 0.26211 | 225.4 | 405.7 | 45.36 | 2.5177 | 0.000699 | 0.60134 |
| 240 | 18693 | 1037.6 | 0.28822 | 247.8 | 446.1 | 48.68 | 2.7020 | 0.000751 | 0.64536 |
| 260 | 20448 | 1135.0 | 0.31528 | 271.1 | 488.0 | 51.97 | 2.8849 | 0.000801 | 0.68905 |
| 280 | 22284 | 1236.9 | 0.34359 | 295.4 | 531.8 | 55.28 | 3.0685 | 0.000852 | 0.73290 |
| 300 | 24232 | 1345.0 | 0.37361 | 321.2 | 578.2 | 58.65 | 3.2552 | 0.000904 | 0.77749 |
| 320 | 26343 | 1462.2 | 0.40617 | 349.2 | 628.6 | 62.14 | 3.4494 | 0.000958 | 0.82388 |
| 340 | 28727 | 1594.5 | 0.44292 | 380.8 | 685.5 | 65.94 | 3.6601 | 0.001017 | 0.87420 |
| 360 | 31739 | 1761.7 | 0.48937 | 420.8 | 757.4 | 70.56 | 3.9167 | 0.001088 | 0.93549 |
| 373.946 | 37551 | 2084.3 | 0.57898 | 497.8 | 896.1 | 79.40 | 4.4070 | 0.001224 | 1.05259 |
Specific enthalpy and entropy for liquid water at temperatures from 32 to 675 °F:
| Temperature | Specific enthalpy, H | Specific entropy, S | |||||
| (°F) | (Btu(IT)/mol) | (Btu(IT)/lb) | (kJ/kg) | (kcal/kg) | (Btu(IT)/(kmol °R)) | (Btu(IT)/lb °R) (kcal/(kg K)) | (kJ/kgK) |
| 32.2 | 0.00 | 0.0003 | 0.0006 | 0.000 | 0.00 | 0.0000 | 0.0000 |
| 40 | 0.32 | 8.11 | 18.9 | 4.50 | 0.65 | 0.0163 | 0.0681 |
| 50 | 0.72 | 18.1 | 42.0 | 10.0 | 1.43 | 0.036 | 0.151 |
| 60 | 1.11 | 27.8 | 64.7 | 15.5 | 2.20 | 0.055 | 0.232 |
| 80 | 1.90 | 47.8 | 111 | 26.6 | 3.70 | 0.093 | 0.390 |
| 100 | 2.70 | 68.0 | 158 | 37.8 | 5.15 | 0.130 | 0.542 |
| 120 | 3.50 | 88.1 | 205 | 48.9 | 6.54 | 0.165 | 0.690 |
| 140 | 4.29 | 108 | 251 | 60.0 | 7.89 | 0.199 | 0.831 |
| 160 | 5.09 | 128 | 298 | 71.3 | 9.20 | 0.232 | 0.970 |
| 180 | 5.89 | 148 | 345 | 82.4 | 10.5 | 0.263 | 1.10 |
| 200 | 6.68 | 168 | 391 | 93.5 | 11.7 | 0.294 | 1.23 |
| 212 | 7.16 | 180 | 419 | 100 | 12.4 | 0.312 | 1.31 |
| 220 | 7.48 | 188 | 438 | 105 | 12.9 | 0.324 | 1.36 |
| 240 | 8.27 | 208 | 485 | 116 | 14.0 | 0.353 | 1.48 |
| 260 | 9.08 | 229 | 532 | 127 | 15.2 | 0.382 | 1.60 |
| 280 | 9.88 | 249 | 579 | 138 | 16.3 | 0.410 | 1.72 |
| 300 | 10.70 | 269 | 627 | 150 | 17.4 | 0.437 | 1.83 |
| 350 | 12.77 | 322 | 748 | 179 | 20.0 | 0.503 | 2.11 |
| 400 | 14.91 | 375 | 873 | 209 | 22.5 | 0.567 | 2.38 |
| 450 | 17.11 | 431 | 1002 | 239 | 25.0 | 0.630 | 2.64 |
| 500 | 19.38 | 488 | 1135 | 271 | 27.4 | 0.689 | 2.88 |
| 550 | 21.80 | 549 | 1277 | 305 | 30.0 | 0.754 | 3.16 |
| 600 | 24.49 | 617 | 1434 | 343 | 32.6 | 0.821 | 3.44 |
| 625 | 26.01 | 655 | 1523 | 364 | 34.1 | 0.858 | 3.59 |
| 650 | 27.70 | 698 | 1622 | 388 | 35.7 | 0.898 | 3.76 |
| 675 | 29.64 | 746 | 1736 | 415 | 37.5 | 0.944 | 3.95 |
Energy per unit mass (Specific energy - mass)
british thermal unit(international table)/pound (Btu(IT)/lb), gigajoule/tonne (GJ/t), kilocalorie/kilogram (kcal/kg) = calorie/gram(cal/g), kilojoule/kilogram (kJ/kg) = joule/gram (J/g), kilowatt hour/kilogram (kWh/kg)
- 1 Btu(IT)/lb = 0.002326 GJ/t = 2.326 kJ/kg = 0.5559 kcal/kg = 0.000646 kWh/kg
- 1 cal/g = 1 kcal/kg = 0.0041868 GJ/t = 4.1868 kJ/kg = 1.8 Btu(IT)/lb = 0.001162 kWh/kg
- 1 GJ/t = 1000 kJ/kg = 429.923 Btu(IT)/lb = 238.846 kcal/kg = 0.278 kWh/kg
- 1 J/g = 1 kJ/kg = 10-3 GJ/t = 0.23885 kcal/kg = 0.4299 Btu(IT)/lb = 0.0002778 kWh/kg
- 1 kcal/kg = 1 cal/g = 0.0041868 GJ/t = 4.1868 kJ/kg = 1.8 Btu(IT)/lb = 0.001162 kWh/kg
- 1 kJ/kg = 1 J/g = 10-3 GJ/t = 0.23885 kcal/kg = 0.4299 Btu(IT)/lb = 0.0002778 kWh/kg
- 1 kWh/kg = 1547.7 Btu(IT)/lb = 3.597 GJ/t = 3597.1 kJ/kg = 860.421 kcal/kg
Temperature
- T°C = (T°F - 32)/1.8
- T°C = TK - 273.15
- T°F = T°C *1.8 + 32
- T°F = (TK - 273.15) * 1.8 + 32
- TK = T°C + 273.15
- TK = T°R /1.8
- T°R = T°F + 459.67
- T°R = 1.8 K
Temperature difference:
- ΔT°C = ΔTK = 1.8*ΔT°F = 1.8*ΔT°R
- ΔT°F = ΔT°R = ΔT°C /1.8 = ΔTK /1.8
- ΔTK = ΔT°C = 1.8*ΔT°F = 1.8*ΔT°R
- ΔT°R = ΔT°F = ΔT°C /1.8 = ΔTK /1.8
• Steam and Condensate
• Thermodynamics
• Water Systems
Compressed Water - Properties vs. Temperature
Specific volume, enthalpy and entropy of compressed water.
Ice - Thermal Properties
Thermal and thermodynamic properties of ice like density, thermal conductivity and specific heat at temperatures from 0 to -100 oC.
Seawater - Properties
Seawater properties like density, saturation pressure, specific heat, electrical conductivity and absolute viscosity.
Steam - Viscosity vs. Pressure
Absolute viscosity of steam at pressure ranging 1 - 10000 psia.
Supercooled Water - Vapor Pressure vs. Temperature
Undercooled water and vapor pressure.
Water - Absolute (Dynamic) Viscosity vs. Temperature and Pressure
Absolute viscosity for water in centipoises for temperatures between 32 - 200oF.
Water - Dynamic and Kinematic Viscosity at Various Temperatures and Pressures
Ionization constant (= dissociation constant = self-ionization constant = ion product = autoprotolysis constant ) of water and heavy water, given as function of temperature (°C and °F) in figures and tables.
Water - Properties vs. Temperature and Pressure
Liquid water properties at temperatures between melting point and boiling point and pressures of 14.7 psia, 1000 psia and 10000 psia (1 atm, 68.1atm and 681 atm).
Water - Saturation Pressure and Specific Weight vs. Temperature
Vapor pressure and specific weight of water at temperatures ranging 32 to 212 oF - Imperial Units.
Water Properties: Vaporization Heat vs. Temperature - Charts and Calculator
Water Vapor - Specific Heat vs. Temperature
Specific heat of Water Vapor - H2O - at temperatures ranging 175 - 6000 K.
Water Vapor Saturation Pressure: Data, Tables & Calculator
Water-Steam Mollier Diagram
