Supercooled Water - Vapor Pressure vs. Temperature
Water freezes at 273.15 K (0 °C, 32 °F) - but can be supercooled (undercooled) without becoming a solid at standard pressure down to almost 224.8 K (−48.3 °C, −55 °F) if it is pure and free of nucleation sites.
Vapor pressure of supercooled water:
Temperature (oC) | Vapor Pressure (kPa) |
0 | 0.6112 |
-5 | 0.4218 |
-10 | 0.2865 |
-15 | 0.1913 |
-20 | 0.1255 |
-25 | 0.08078 |
-30 | 0.05094 |
-35 | 0.03141 |
-40 | 0.01891 |
- 1 Pa = 1.45×10-4 psi (lbf/in2)
Compressed Water - Properties vs. Temperature
Specific volume, enthalpy and entropy of compressed water.
Water - Properties vs. Temperature and Pressure
Liquid water properties at temperatures between melting point and boiling point and pressures of 14.7 psia, 1000 psia and 10000 psia (1 atm, 68.1atm and 681 atm).
Water - Saturation Pressure and Specific Weight vs. Temperature
Vapor pressure and specific weight of water at temperatures ranging 32 to 212 oF - Imperial Units.
Water Properties: Vaporization Heat vs. Temperature - Charts and Calculator
