Melting point: The temperature at which a solid turns into a liquid.
The melting point of water is dependent of the pressure above the ice (solid water), and the melting point or freezing temperature decreases with increasing pressure. By definition 0 °C is at the melting point of water at 1 atmosphere pressure.
Online Ice to Water Melting Point Calculator
The calculator below can be used to calculate the water melting point at given pressures.
The output temperature is given as °C, °F, K and °R.
Note! Pressure must be within the ranges 0.01-2000 bara, 0.1-29 000 psia, 5-1500 000 mm Hg or 0.2-59000 in Hg.
Choose the actual unit of pressure:
See also other properties of Water at varying temperature and pressure : Boiling points at high pressure, Boiling points at vacuum pressure, Density and specific weight, Dynamic and kinematic viscosity, Enthalpy and entropy, Heat of vaporization, Ionization Constant, pKw , of normal and heavy water, Prandtl number, Properties at Gas-Liquid Equilibrium Conditions, Saturation pressure, Specific gravity, Specific heat (heat capacity), Specific volume, Thermal conductivity, Thermal diffusivity and Vapour pressure at gas-liquid equilibrium .
| Pressure | Temperature | |||||
| (MPa) | (bara) | (psia) | (mm Hg) | (in Hg) | (°C) | (°F) |
| 0.000612 | 0.00612 | 0.089 | 4.59 | 0.18 | 0.01 | 32.02 |
| 0.1 | 1.01325 | 14.7 | 750 | 29.5 | 0.0026 | 32.00 |
| 1 | 10 | 145 | 7501 | 295 | -0.064 | 31.88 |
| 2 | 20 | 290 | 15001 | 591 | -0.14 | 31.75 |
| 5 | 50 | 725 | 37503 | 1476 | -0.37 | 31.33 |
| 10 | 100 | 1450 | 75006 | 2953 | -0.75 | 30.65 |
| 15 | 150 | 2176 | 112509 | 4429 | -1.14 | 29.95 |
| 20 | 200 | 2901 | 150012 | 5906 | -1.54 | 29.23 |
| 30 | 300 | 4351 | 225019 | 8859 | -2.36 | 27.75 |
| 40 | 400 | 5802 | 300025 | 11812 | -3.21 | 26.22 |
| 50 | 500 | 7252 | 375031 | 14765 | -4.09 | 24.64 |
| 60 | 600 | 8702 | 450037 | 17718 | -5.00 | 23.00 |
| 70 | 700 | 10153 | 525043 | 20671 | -5.94 | 21.31 |
| 80 | 800 | 11603 | 600049 | 23624 | -6.91 | 19.56 |
| 90 | 900 | 13053 | 675056 | 26577 | -7.91 | 17.76 |
| 100 | 1000 | 14504 | 750062 | 29530 | -8.94 | 15.91 |
| 120 | 1200 | 17405 | 900074 | 35436 | -11.09 | 12.04 |
| 140 | 1400 | 20305 | 1050086 | 41342 | -13.35 | 7.97 |
| 160 | 1600 | 23206 | 1200099 | 47248 | -15.73 | 3.69 |
| 180 | 1800 | 26107 | 1350111 | 53154 | -18.22 | -0.80 |
| 200 | 2000 | 29008 | 1500123 | 59060 | -20.83 | -5.49 |
• Melting and Freezing Points
• Steam and Condensate
• Thermodynamics
• Thermodynamics
• Water Systems
Compressed Water - Properties vs. Temperature
Specific volume, enthalpy and entropy of compressed water.
Evaporation of water from a water surface - like a swimming pool or an open tank - depends on water temperature, air temperature, air humidity and air velocity above the water surface - online calculator.
Ice - Properties
Properties like Youngs modulus, tensile strength, compressive strength and fracture of toughness for ice.
Ice - Thermal Properties
Thermal and thermodynamic properties of ice like density, thermal conductivity and specific heat at temperatures from 0 to -100 oC.
Saturated Ice and Steam - Thermodynamic Properties
Thermodynamic properties of saturated ice and steam - specific volume, enthalpy and entropy.
Soft or Hard Water
Carbonates dissolved in water.
Supercooled Water - Vapor Pressure vs. Temperature
Undercooled water and vapor pressure.
Water - Dynamic and Kinematic Viscosity at Various Temperatures and Pressures
Ionization constant (= dissociation constant = self-ionization constant = ion product = autoprotolysis constant ) of water and heavy water, given as function of temperature (°C and °F) in figures and tables.
Water - Properties vs. Temperature and Pressure
Liquid water properties at temperatures between melting point and boiling point and pressures of 14.7 psia, 1000 psia and 10000 psia (1 atm, 68.1atm and 681 atm).
Water Properties: Vaporization Heat vs. Temperature - Charts and Calculator
Water Vapor Saturation Pressure: Data, Tables & Calculator
