Ice - Thermal Properties
Thermal properties of ice:
Temperature
- t -
(oC)
Density
- ρ -
(kg/m3)
Thermal
Conductivity
- k -
(W/mK)
other units
Specific
Heat
- cp -
(kJ/kgK)
0.01 (Water) 999.8
0 916.2 2.22 2.050
-5 917.5 2.25 2.027
-10 918.9 2.30 2.000
-15 919.4 2.34 1.972
-20 919.4 2.39 1.943
-25 919.6 2.45 1.913
-30 920.0 2.50 1.882
-35 920.4 2.57 1.851
-40 920.8 2.63 1.818
-50 921.6 2.76 1.751
-60 922.4 2.90 1.681
-70 923.3 3.05 1.609
-80 924.1 3.19 1.536
-90 924.9 3.34 1.463
-100 925.7 3.48 1.389
  • Officially water at 0 oC is ice
Vapour Pressure Ice
Ice - Vapour Pressure
Temperature
(oC)
-220 -200 -150 -100 -90 -80 -70 -60 -50 -40 -30 -20 -10 -5 -0.01
Vapour Pressure
(Pa abs)
2.06×10-37 3.31×10-24 9×10-10 0.0014 0.0097 0.055 0.261 1.08 3.94 12.84 38 103.2 259.9 401.7 611.7
Download and print Ice - Vapor Pressure vs. Temperature chart
Densities
Environment
Material Properties
Freezing Mixtures and Cooling Agents
Freezing mixtures, cooling agents and freezing points.
Friction - Coefficients for Common Materials and Surfaces
Find friction coefficients for various material combinations, including static and kinetic friction values. Useful for engineering, physics, and mechanical design applications.
Ice - Properties
Properties like Youngs modulus, tensile strength, compressive strength and fracture of toughness for ice.
Ice - Safe Load vs. Thickness
Safe loads vs. thickness for clear and solid ice.
Ice Loaded Pipelines
Ice coat weight on horizontal pipe lines.
Saturated Ice and Steam - Thermodynamic Properties
Thermodynamic properties of saturated ice and steam - specific volume, enthalpy and entropy.
Solids - Specific Heats
Water-Steam Mollier Diagram
