Thermodynamic properties of water:
- Boiling temperature (at 101.325 kPa): 99.974 °C = 211.953 °F
- Bulk modulus elasticity : 2.15×109 Pa or N/m2
- Critical temperature : 373.946 °C = 705.103 °F
- Critical pressure : 217.7 atm = 220.6 bar = 22.06 MPa (MN/m2) = 3200 psi (=lbf/in2)
- Critical density: 0.322 g/cm3 = 0.62478 slug/ft3 = 20.1018 lbm/ft3
- Ionization constant, pKw (at 25°C): 13.995
- Latent heat of melting: 334 kJ/kg = 144 Btu(IT)/lb
- Latent heat of evaporation(at 100°C): 40.657 kJ/mol = 2256 kJ/kg = 970 Btu(IT)/lb
- Maximum density (at 4 oC): 999.975 kg/m3 = 1.9403 slug/ft3 = 8.34519 lbm/gal(US)
- Melting temperature (at 101.325 kPa): 0 °C = 32°F
- Molar mass: 18.01527 g/mol
- pH (at 25°C): 6.9976
- Specific heat (Cp) water (at 15°C/60°F): 4.187 kJ/kgK = 1.001 Btu(IT)/(lbm °F) or kcal/(kg K)
- Specific heat ice: 2.108 kJ/kgK = 0.5035 Btu(IT)/(lbm °F) or kcal/(kg K)
- Specific heat water vapor: 1.996 kJ/kgK =0.4767 Btu(IT)/(lbm °F) or kcal/(kg K)
- Specific Weight (at 4 oC): 9.806 kN/m3 = 62.43 lbf/ft3
- Thermal expansion from 4 oC to 100 oC: 4.2×10-4 (Note! - volumetric temperature expansion of water is not linear with temperature)
- Triple point pressure: 0.00604 atm = 0.00612 bar = 611.657 Pa = 0.08871 psi (=lbf/in2)
- Triple point temperature: 0.01 °C = 32.02 °F
Follow the links below to get values for the listed properties of liquid water at varying pressure and temperature :
- Boiling points at high pressure
- Boiling points at vacuum pressure
- Density, specific weight and thermal expansion coefficient
- Dynamic and kinematic viscosity
- Enthalpy and entropy
- Heat of vaporization
- Ionization Constant, pKw , of normal and heavy water
- Melting points at high pressure
- Prandtl number
- Properties at gas-liquid equilibrium condition
- Saturation pressure
- Specific gravity
- Specific heat (heat capacity)
- Specific volume
- Thermal conductivity
- Thermal diffusivity
For each topic, there are figures and tables showing the variations in properties with temperature. Calculators giving the properties at specified temperatures are also available. All properties are given in both SI and imperial units.
as well as Thermophysical properties of: Acetone, Acetylene, Air, Ammonia, Argon, Benzene, Butane, Carbon dioxide, Carbon monoxide, Ethane, Ethanol, Ethylene, Helium, Hydrogen, Hydrogen sulfide, Methane, Methanol, Nitrogen, Oxygen, Pentane, Propane, Toluene and Heavy water, D2O.
• Densities
• Environment
• Steam and Condensate
Carbon Dioxide (CO₂) Properties & Characteristics: Density, Thermal Data & More
Compressed Water - Properties vs. Temperature
Specific volume, enthalpy and entropy of compressed water.
Electric Heating of Mass
Electric heating and temperature change vs. energy supplied.
Evaporation of water from a water surface - like a swimming pool or an open tank - depends on water temperature, air temperature, air humidity and air velocity above the water surface - online calculator.
Evaporative Cooling
Evaporative cooling tutorial.
Great Sensible Heat Factor - GSHF
The Great Sensible Heat Factor is the ratio sensible to total heat in a cooling coil.
Heat Capacity
Heating Water by Injecting Steam
Water can be heated by injecting steam.
Ice - Thermal Properties
Thermal and thermodynamic properties of ice like density, thermal conductivity and specific heat at temperatures from 0 to -100 oC.
Latent Heat Flow
Liquid Densities
Methane (CH₄): Thermophysical Properties and Phase Diagram
Methanol - Thermophysical Properties
Chemical, physical and thermal properties of methanol, CH3OH (also called carbinol, wood alcohol, hydroxy methyl and methyl alcohol). Phase diagram included.
Mixing Fluids
Final mass and temperature when mixing fluids.
Moist Air - Enthalpy
Pipes Submerged in Oil or Fat - Heat Emission
Heat emission from steam or water heating pipes submerged in oil or fat - forced and natural circulation.
Prandtl Number
A dimensionless number approximating the ratio of momentum diffusivity to thermal diffusivity.
Pumping Water - Energy Cost Calculator
Calculate the energy cost of pumping water.
Saturated Ice and Steam - Thermodynamic Properties
Thermodynamic properties of saturated ice and steam - specific volume, enthalpy and entropy.
Soft or Hard Water
Carbonates dissolved in water.
Soft or Hard Water
Standardized Enthalpies and Entropies
Standardized enthalpies and entropies for some common substances.
Steam - Viscosity vs. Pressure
Absolute viscosity of steam at pressure ranging 1 - 10000 psia.
Steam Entropy
Basic steam thermodynamics - entropy diagram.
Supercooled Water - Vapor Pressure vs. Temperature
Undercooled water and vapor pressure.
Thermodynamic Terms - Functions and Relations
Third Law of Thermodynamics
The entropy of a substance is zero if the absolute temperature is zero.
Water - Absolute (Dynamic) Viscosity vs. Temperature and Pressure
Absolute viscosity for water in centipoises for temperatures between 32 - 200oF.
Ionization constant (= dissociation constant = self-ionization constant = ion product = autoprotolysis constant ) of water and heavy water, given as function of temperature (°C and °F) in figures and tables.
Water - Properties vs. Temperature and Pressure
Liquid water properties at temperatures between melting point and boiling point and pressures of 14.7 psia, 1000 psia and 10000 psia (1 atm, 68.1atm and 681 atm).
Water - Saturation Pressure and Specific Weight vs. Temperature
Vapor pressure and specific weight of water at temperatures ranging 32 to 212 oF - Imperial Units.
Water Properties: Vaporization Heat vs. Temperature - Charts and Calculator
Water Vapor - Specific Heat vs. Temperature
Specific heat of Water Vapor - H2O - at temperatures ranging 175 - 6000 K.
Water-Steam Mollier Diagram
