The total steam consumption for the heating process can be calculated as
q = (0.035 kg/s) (300 s)
= 10.5 kg
Thermodynamics of steam and condensate systems.
Saturated Steam Table with properties like boiling point, specific volume, density, specific enthalpy, specific heat and latent heat of vaporization.
Vapor and steam enthalpy, specific enthalpy of saturated liquid, saturated vapor and superheated vapor.
