Temperature Difference (oC
Biomass fuels and their energy content.
Convert between energy units
Energy density - by weight and volume - for some ways to store energy
Fluid energy transfer.
Content of hot water in some common used fixtures - basins, sinks and baths.
Heat vs. work vs. energy.
Hot water can be circulated through a return pipe if it's instantly required at the fixtures.
Hot water heating temperatures adapts to outdoor temperatures.
Power potential vs. head and flow rate.
Calculate the potential of pressure energy in a incompressible fluid.
Melting points and latent energy of salt hydrates.
Vapor and steam enthalpy, specific enthalpy of saturated liquid, saturated vapor and superheated vapor.
Energy stored as sensible heat in materials.
