Fixtures - Hot Water Content
The table below can be used as an indication of normal hot water content in fixtures:
Fixtures | Contents | |
liter | gal | |
Basin, normal | 5 | 1 |
Basin, full | 9 | 2 |
Sink, normal | 22 | 5 |
Sink, full | 45 | 10 |
Bath | 135 - 180 | 30 - 40 |
• Water Systems
Domestic Hot Water Heaters - Sizing
Domestic Hot-Water sizing equations - heating capacity, recovery rate and power supply.
Domestic Hot Water Service Systems - Design Procedures
Design procedures for domestic hot water service systems.
Energy Accumulated in Heated Water - kWh
Fixture Water Consumption and Required Water Supply
Supply requirements for common fixtures.
Fixtures Hot Water Consumption
Hot water consumption of fixtures like basins, showers, sinks and baths.
Hot and Cold Water Pipes Sizing
Recommended dimensions hot and cold water pipes.
Hot Water Circulation System - Return Pipes
Hot water can be circulated through a return pipe if it's instantly required at the fixtures.
Hot Water Consumption vs. Occupants
Consumption of hot water per person or occupant.
Hot Water Storage Tanks - Capacities vs. Dimensions
Dimensions and capacities of hot-water storage tanks.
Hot Water Supply - Flow Rates to Fixtures
Hot water consumption of some common equipment as basins, sinks, baths and showers.
Water Supply Fixture Units - WSFU vs. GPM and Liters/sec
Converting WSFU - Water Supply Fixture Units - to GPM.
