Domestic Hot Water Heaters - Sizing
Domestic hot-water systems supplies taps in houses or buildings with hot water.
Output Heating Capacity
Output heating capacity of a domestic hot-water system:
hout = q ρ dt cp (1)
hout = heating capacity, output (Btu/h)
q = flow rate (gph)
ρ = 8.34 - density of water (lbs/gal)
dt = temperature rise (oF)
cp = 1.0 - specific heat of water (Btu/lboF)
Input Heating Capacity
Input heating capacity of a domestic hot-water system:
hin = q ρ dt cp / μ (2)
hin = heating capacity, input (Btu/h)
μ = efficiency
Recovery Rate
Recovery rate for an electrical heater in a domestic hot water system:
RR = hin μ / (dt ρ)
= P (3413 Btu/kW) / (dt ρ) (3)
RR = recovery rate (gal/h)
P = electrical power supplied by heater (kW)
Temperature Rise
Temperature rise in an electrical heater in a domestic hot-water system:
dt = hin μ / (q ρ)
= P (3413 Btu/kW) / qρ (4)
Electrical Power Supply
Electrical power supply to a domestic hot-water systems:
P = q ρ dt cp / (3413 Btu/kW) (5)
• Water Systems
Domestic Service Water Supply Systems
Introduction to general design of domestic service water supply systems - with pressurized or gravity tanks.
Fixtures - Hot Water Content
Content of hot water in some common used fixtures - basins, sinks and baths.
Hot Water Circulation System - Return Pipes
Hot water can be circulated through a return pipe if it's instantly required at the fixtures.
Hot Water Consumption vs. Occupants
Consumption of hot water per person or occupant.
Hot Water Storage Tanks - Capacities vs. Dimensions
Dimensions and capacities of hot-water storage tanks.
Hot Water Supply - Flow Rates to Fixtures
Hot water consumption of some common equipment as basins, sinks, baths and showers.
Water Consumption and Activities
Typical human activities and average water consumption
