Hot Water Consumption vs. Occupants
Flow rate and temperature are the primary factors to be determined in the hydraulic and thermal design of water-heating and piping systems.
The table below indicates hot water consumption per occupant or person in typical buildings:
Type of buildingConsumption per occupantPeak demand per occupantStorage per occupant
liter/daygal/dayliter/hrgal/hrlitergal
Factories (no process) 22 - 45 5 - 10 9 2 5 1
Hospitals, general 160 35 30 7 27 6
Hospitals, mental 110 25 22 5 27 6
Hostels 90 20 45 10 30 7
Hotels 90 - 160 20 - 35 45 10 30 7
Houses and flats 90 - 160 20 - 35 45 10 30 7
Offices 22 5 9 2 5 1
Schools, boarding 115 25 20 4 25 5
Schools, day 15 3 9 2 5 1
Water Systems
Domestic Hot Water Heaters - Sizing
Domestic Hot-Water sizing equations - heating capacity, recovery rate and power supply.
Domestic Hot Water Service Systems - Design Procedures
Design procedures for domestic hot water service systems.
Domestic Water Supply - Lime Deposits
Lime deposited vs. temperature and water consumption.
Fixtures - Hot Water Content
Content of hot water in some common used fixtures - basins, sinks and baths.
Fixtures Hot Water Consumption
Hot water consumption of fixtures like basins, showers, sinks and baths.
Hot and Cold Water Pipes Sizing
Recommended dimensions hot and cold water pipes.
Hot Water Circulation System - Return Pipes
Hot water can be circulated through a return pipe if it's instantly required at the fixtures.
Hot Water Storage Tanks - Capacities vs. Dimensions
Dimensions and capacities of hot-water storage tanks.
Hot Water Supply - Flow Rates to Fixtures
Hot water consumption of some common equipment as basins, sinks, baths and showers.
Water Consumption and Activities
Typical human activities and average water consumption
Water Supply Fixture Units - WSFU vs. GPM and Liters/sec
Converting WSFU - Water Supply Fixture Units - to GPM.
