Hot Water Storage Tanks - Capacities vs. Dimensions
Hot-water storage tank dimensions and capacities:
Hot Water Storage Tanks - Capacities vs. Dimensions of Tanks
Tank Diameter (inches)
Hot-Water Storage Capacity (Gallons)
Tank Length (ft)
12345678910
20 16 32 48 66 82 98 114 131 147 163
22 20 40 60 80 100 120 140 160 180 200
24 24 48 72 96 120 144 168 192 216 240
30 37 74 110 147 184 220 257 294 330 367
36 53 106 159 212 265 317 370 423 476 529
42 72 144 216 288 360 432 504 576 648 720
  • 1 ft (foot) = 0.3048 m
  • 1 in (inch) = 25.4 mm = 2.54 cm = 0.0254 m
  • 1 Gallon (U.S.) = 3.785x10-3 m3 = 3.785 dm3 (liter)
Water Systems
Hot and cold water service systems - design properties, capacities, sizing and more.
Content in Horizontal - or Sloped - Cylindrical Tanks or Pipes
Volume of partly filled horizontal or sloped cylindrical tanks or pipes - online calculator.
Cylindrical Tanks - Volumes
Volume in US gallons and liters.
Domestic Hot Water Heaters - Sizing
Domestic Hot-Water sizing equations - heating capacity, recovery rate and power supply.
Domestic Hot Water Service Systems - Design Procedures
Design procedures for domestic hot water service systems.
Domestic Water Supply - Lime Deposits
Lime deposited vs. temperature and water consumption.
Fixtures - Hot Water Content
Content of hot water in some common used fixtures - basins, sinks and baths.
Hot Water Circulation System - Return Pipes
Hot water can be circulated through a return pipe if it's instantly required at the fixtures.
Hot Water Consumption vs. Occupants
Consumption of hot water per person or occupant.
Hot Water Supply - Flow Rates to Fixtures
Hot water consumption of some common equipment as basins, sinks, baths and showers.
Hot Water Supply vs. Fixtures Consumption
Design hot water consumption of fixtures - basins, showers, sinks and baths.
Rectangular Tanks - Volumes
Tank volume per foot depth.
