The figure redraws when the parameters in the calculator are changed and calculated.
The chart below can be used for horizontal tanks or pipes where the slope is zero.
Liquid Level ratio (% of max height) | 0 | 5 | 10 | 15 | 20 | 25 | 30 | 35 | 40 | 45 | 50 | 55 | 60 | 65 | 70 | 75 | 80 | 85 | 90 | 95 | 100 |
Liquid Fill (% of max volume) | 0 | 2 | 5 | 9 | 14 | 20 | 25 | 31 | 37 | 44 | 50 | 56 | 63 | 69 | 75 | 80 | 86 | 91 | 95 | 98 | 100 |
Volume in US gallons and liters.
Calculating excavation slope.
Fuel oil storage tanks dimensions.
Heat loss from insulated and non insulated sheltered and exposed oil tanks and pipes.
Due to evaporation the heat loss from an open water tank like a swimming pool may be considerable.
Dimensions and capacities of hot-water storage tanks.
Heat loss from insulated and uninsulated, sheltered and exposed heated oil tanks.
Water content in steel pipes and copper tubes.
Tank volume per foot depth.
Septic systems handles waste from drain systems.
Convert slopes pitch between degrees, gradients and grades.
Liquid content in partly filled horizontal pipes or tanks.
