Beams and Columns
Aluminum Channels
Dimensions and static parameters of aluminum channels.
Aluminum I-Beams
Dimensions and static properties of aluminum I-beams - Imperial units.
American Standard Beams - S Beam
American Standard Steel C Channels
American Wide Flange Beams
Area Moment of Inertia - Typical Cross Sections I
Area Moment of Inertia - Typical Cross Sections II
Area Moment of Inertia, Moment of Inertia for an Area or Second Moment of Area for typical cross section profiles.
Area Moment of Inertia Converter
Convert between Area Moment of Inertia units.
Beams - Fixed at Both Ends - Continuous and Point Loads
Beams - Supported at Both Ends - Continuous and Point Loads
Beams Natural Vibration Frequency
Estimate structures natural vibration frequency.
Cantilever Beams - Moments and Deflections
Continuous Beams - Moment and Reaction Support Forces
Moments and reaction support forces with distributed or point loads.
An introduction to density, specific weight and specific gravity.
Ducts or Pipes through Steel Joists - Maximum Sizes
Maximum sizes of ducts or pipes through K series joists.
Euler's Column Formula
Calculate buckling of columns.
Floor Joist Capacities
Floors - Live Loads
Force
Glue-Laminated Timber - Dimensions
Common sizing of glue-laminated timber.
HE-A Steel Beams
HE-B Steel Beams
HE-M Steel Beams
Properties of HE-M profile steel beams.
Horizontal Roof Rafters - Maximum Spans
Douglas Fir in horizontal roof rafters and maximum spans.
Machine Stress Rated (MSR) and Machine Evaluated (MEL) Lumber
Grading of lumber in North America
Maximum Floor Joist Span
No. 1 and No. 2 Grade of Douglas fir and maximum span floor joists - imperial units
Normal Flange I-Beams
Radius of Gyration in Structural Engineering
Radius of gyration describes the distribution of cross sectional area in columns around their centroidal axis.
Section Modulus - Unit Converter
Convert between Elastic Section Modulus units.
Softwood and Hardwood - Structural Strength Classes
Strength classes, bending stress and mean density of hardwood and softwood
Square Hollow Structural Sections - HSS
Steel Angles - Equal Legs
Steel Angles - Unequal Legs
Steel Pipe Columns - Allowable Loads
Allowable concentric loads for steel pipe columns.
Structural Lumber - Section Sizes
Basic size, area, moments of inertia and section modulus for timber - metric units.
Structural Lumber - Properties
Three-Hinged Arches - Continuous and Point Loads
Support reactions and bending moments.
Trusses
Common types of trusses.
W Steel Beams - Allowable Uniform Loads
Allowable uniform loads.
W-Beams - American Wide Flange Beams
Weight of Beams - Stress and Strain
Stress and deformation of vertical beams due to own weight.
Wood Beams - Strength of Material
Wood Columns - Safe Loads
Safe loads for wood columns.
Wood Headers - Max. Supported Weight
Wood, Panel and Structural Timber Products - Mechanical Properties
Density, fibre stress, compressive strength and modulus of elasticity of clear wood, panel and structural timber products.
