h
(mm)
I-shaped cross-section beams:
Dimensions and static properties of aluminum I-beams - Imperial units.
Area Moment of Inertia, Moment of Inertia for an Area or Second Moment of Area for typical cross section profiles.
Calculate the acting forces and moments when elevating drawbridges or beams.
Properties of HE-M profile steel beams.
Stress and deformation of vertical beams due to own weight.
