- Beams - Supported at Both Ends - Continuous and Point Loads
- Beams - Fixed at One End and Supported at the Other - Continuous and Point Loads
- Beams - Fixed at Both Ends - Continuous and Point Loads
Beam Fixed at One End and Supported at the Other - Single Point Load
Bending Moment
M A = - F a b (L + b) / (2 L 2 ) (1a)
M A = moment at the fixed end (Nm, lb f ft)
F = load (N, lb f )
M F = R b b (1b)
M F = moment at point of load F (Nm, lb f ft)
R b = support load at support B (N, lb f )
Deflection
δ F = F a 3 b 2 (3 L + b) / (12 L 3 E I) (1c)
δ F = deflection (m, ft)
E = Modulus of Elasticity (Pa (N/m 2 ), N/mm 2 , psi)
I = Area Moment of Inertia (m 4 , mm 4 , in 4 )
Support Reactions
R A = F b (3 L 2 - b 2 ) / (2 L 3 ) (1d)
R A = support force in A (N, lb f )
R B = F a 2 (b + 2 L ) / (2 L 3 ) (1f)
R B = support force in B (N, lb f )
Beam Fixed at One End and Supported at the Other - Continuous Load
Bending Moment
M A = - q L 2 / 8 (2a)
q = continuous load (N/m, lb f /ft)
M 1 = 9 q L 2 / 128 (2b)
M 1 = maximum moment at x = 0.625 L (Nm, lb f ft)
Deflection
δ max = q L 4 / (185 E I) (2c)
δ max = max deflection at x = 0.579 L (m, ft)
δ 1/2 = q L 4 / (192 E I) (2d)
δ 1/2 = deflection at x = L / 2 (m, ft)
Support Reactions
R A = 5 q L / 8 (2e)
R B = 3 q L / 8 (2f)
Beam Fixed at One End and Supported at the Other - Continuous Declining Load
Bending Moment
M A = - q L 2 / 15 (3a)
q = continuous declining load (N/m, lb f /ft)
M 1 = q L 2 / 33.6 (3b)
M 1 = maximum moment at x = 0.553 L (Nm, lb f ft)
Deflection
δ max = q L 4 / (419 E I) (3c)
δ max = max deflection at x = 0.553 L (m, ft)
δ 1/2 = q L 4 / (427 E I) (3d)
Support Reactions
R A = 2 q L / 5 (3e)
R B = q L / 10 (3f)
Beam Fixed at One End and Supported at the Other - Moment at Supported End
Bending Moment
M A = -M B / 2 (4a)
Deflection
δ max = M B L 2 / (27 E I) (4b)
δ max = max deflection at x = 2/3 L (m, ft)
Support Reactions
R A = 3 M B / (2 L) (4c)
R B = - 3 M B / (2 L) (4d)
• Beams and Columns
• Mechanics
• Statics
Aluminum I-Beams
Dimensions and static properties of aluminum I-beams - Imperial units.
American Standard Beams - S Beam
American Standard Steel C Channels
American Wide Flange Beams
Area Moment of Inertia - Typical Cross Sections I
Area Moment of Inertia - Typical Cross Sections II
Area Moment of Inertia, Moment of Inertia for an Area or Second Moment of Area for typical cross section profiles.
Area Moment of Inertia Converter
Convert between Area Moment of Inertia units.
Beams Natural Vibration Frequency
Estimate structures natural vibration frequency.
Cantilever Beams - Moments and Deflections
Continuous Beams - Moment and Reaction Support Forces
Moments and reaction support forces with distributed or point loads.
Drawbridge - Force and Moment vs. Elevation
Calculate the acting forces and moments when elevating drawbridges or beams.
Floor Joist Capacities
Floors - Live Loads
HE-A Steel Beams
HE-B Steel Beams
Normal Flange I-Beams
Section Modulus - Unit Converter
Convert between Elastic Section Modulus units.
Square Hollow Structural Sections - HSS
Steel Angles - Equal Legs
Steel Angles - Unequal Legs
Stress
Three-Hinged Arches - Continuous and Point Loads
Support reactions and bending moments.
Trusses
Common types of trusses.
W Steel Beams - Allowable Uniform Loads
Allowable uniform loads.
W-Beams - American Wide Flange Beams
Weight of Beams - Stress and Strain
Stress and deformation of vertical beams due to own weight.
