The standard method for specifying the dimensions of a American Standard Steel Channels is like C 5 x 9. which is a beam 5 inches deep with a weight 9 lb/ft.
I-shaped cross-section beams:
Area Moment of Inertia, Moment of Inertia for an Area or Second Moment of Area for typical cross section profiles.
Common types of trusses.
