American Wide Flange Steel Beams (W-Beams) - Dimensions and Properties in Imperial Units
W-beams - wide flange beams - are stout, sturdy beams with wide flanges positioned perpendicularly to the web of the material giving them their characteristic shape and distinguishing them from I-beams.
Properties in imperial units of American Wide Flange Beams according ASTM A6 are indicated below.
For full table with Depth, Width, Web and Flange Thickness and Section Area - rotate the screen!
| Designation Imperial (in x lb/ft) | Depth h (in) | Width w (in) | Web Thickness tw (in) | Flange Thickness tf (in) | Sectional Area (in2) | Weight (lbf/ft) | Static Parameters | |||
| Moment of Inertia | Elastic Section Modulus | |||||||||
| Ix (in4) | Iy (in4) | Sx (in3) | Sy (in3) | |||||||
| W 27 x 178 | 27.8 | 14.09 | 0.725 | 1.190 | 52.3 | 178 | 6990 | 555 | 502 | 78.8 |
| W 27 x 161 | 27.6 | 14.02 | 0.660 | 1.080 | 47.4 | 161 | 6280 | 497 | 455 | 70.9 |
| W 27 x 146 | 27.4 | 14 | 0.605 | 0.975 | 42.9 | 146 | 5630 | 443 | 411 | 63.5 |
| W 27 x 114 | 27.3 | 10.07 | 0.570 | 0.930 | 33.5 | 114 | 4090 | 159 | 299 | 31.5 |
| W 27×102 | 27.1 | 10.02 | 0.515 | 0.830 | 30.0 | 102 | 3620 | 139 | 267 | 27.8 |
| W 27 x 94 | 26.9 | 10 | 0.490 | 0.745 | 27.7 | 94 | 3270 | 124 | 243 | 24.8 |
| W 27 x 84 | 26.7 | 9.96 | 0.460 | 0.640 | 24.8 | 84 | 2850 | 106 | 213 | 21.2 |
| W 24 x 162 | 25 | 13 | 0.705 | 1.220 | 47.7 | 162 | 5170 | 443 | 414 | 68.4 |
| W 24 x 146 | 24.7 | 12.9 | 0.650 | 1.090 | 43.0 | 146 | 4580 | 391 | 371 | 60.5 |
| W 24 x 131 | 24.5 | 12.9 | 0.605 | 0.960 | 38.5 | 131 | 4020 | 340 | 329 | 53.0 |
| W 24 x 117 | 24.3 | 12.8 | 0.55 | 0.850 | 34.4 | 117 | 3540 | 297 | 291 | 46.5 |
| W 24×104 | 24.1 | 12.75 | 0.500 | 0.750 | 30.6 | 104 | 3100 | 259 | 258 | 40.7 |
| W 24 x 94 | 24.1 | 9.07 | 0.515 | 0.875 | 27.7 | 94 | 2700 | 109 | 222 | 24.0 |
| W 24 x 84 | 24.1 | 9.02 | 0.470 | 0.770 | 24.7 | 84 | 2370 | 94.4 | 196 | 20.9 |
| W 24 x 76 | 23.9 | 9 | 0.440 | 0.680 | 22.4 | 76 | 2100 | 82.5 | 176 | 18.4 |
| W 24 x 68 | 23.7 | 8.97 | 0.415 | 0.585 | 20.1 | 68 | 1830 | 70.4 | 154 | 15.7 |
| W 24 x 62 | 23.7 | 7.04 | 0.430 | 0.590 | 18.2 | 62 | 1550 | 34.5 | 131 | 9.8 |
| W 24 x 55 | 23.6 | 7.01 | 0.395 | 0.505 | 16.2 | 55 | 1350 | 29.1 | 114 | 8.3 |
| W 21 x 147 | 22.1 | 12.51 | 0.720 | 1.150 | 43.2 | 147 | 3630 | 376 | 329 | 60.1 |
| W 21 x 132 | 21.8 | 12.44 | 0.650 | 1.035 | 38.8 | 132 | 3220 | 333 | 295 | 53.5 |
| W 21 x 122 | 21.7 | 12.39 | 0.600 | 0.960 | 35.9 | 122 | 2960 | 305 | 273 | 49.2 |
| W 21 x 111 | 21.5 | 12.34 | 0.550 | 0.875 | 32.7 | 111 | 2670 | 274 | 249 | 44.5 |
| W 21×101 | 21.4 | 12.29 | 0.500 | 0.800 | 29.8 | 101 | 2420 | 248 | 227 | 40.3 |
| W 21 x 93 | 21.6 | 8.42 | 0.580 | 0.930 | 27.3 | 93 | 2070 | 92.9 | 192 | 22.1 |
| W 21 x 83 | 21.4 | 8.36 | 0.515 | 0.835 | 24.3 | 83 | 1830 | 81.4 | 171 | 19.5 |
| W 21 x 73 | 21.2 | 8.3 | 0.455 | 0.740 | 21.5 | 73 | 1600 | 70.6 | 151 | 17.0 |
| W 21 x 68 | 21.1 | 8.27 | 0.430 | 0.685 | 20.0 | 68 | 1480 | 64.7 | 140 | 15.7 |
| W 21 x 62 | 21 | 8.24 | 0.400 | 0.615 | 18.3 | 62 | 1330 | 57.5 | 127 | 13.9 |
| W 21 x 57 | 21.1 | 6.56 | 0.405 | 0.650 | 16.7 | 57 | 1170 | 30.6 | 111 | 9.4 |
| W 21 x 50 | 20.8 | 6.53 | 0.380 | 0.535 | 14.7 | 50 | 984 | 24.9 | 94.5 | 7.6 |
| W 21 x 44 | 20.7 | 6.5 | 0.350 | 0.450 | 13.0 | 44 | 843 | 20.7 | 81.6 | 6.4 |
| W 18 x 119 | 19 | 11.27 | 0.655 | 1.060 | 35.1 | 119 | 2190 | 253 | 231 | 44.9 |
| W 18×106 | 18.7 | 11.2 | 0.590 | 0.940 | 31.1 | 106 | 1910 | 220 | 204 | 39.4 |
| W 18 x 97 | 18.6 | 11.15 | 0.535 | 0.870 | 28.5 | 97 | 1750 | 201 | 188 | 36.1 |
| W 18 x 86 | 18.4 | 11.09 | 0.480 | 0.770 | 25.3 | 86 | 1530 | 175 | 166 | 31.6 |
| W 18 x 76 | 18.2 | 11.04 | 0.425 | 0.680 | 22.3 | 76 | 1330 | 152 | 146 | 27.6 |
| W 18 x 71 | 18.5 | 7.64 | 0.495 | 0.810 | 20.8 | 71 | 1170 | 60.3 | 127 | 15.8 |
| W 18 x 65 | 18.4 | 7.59 | 0.450 | 0.750 | 19.1 | 65 | 1070 | 54.8 | 117 | 14.4 |
| W 18 x 60 | 18.2 | 7.56 | 0.415 | 0.695 | 17.6 | 60 | 984 | 50.1 | 108 | 13.3 |
| W 18 x 55 | 18.1 | 7.53 | 0.390 | 0.630 | 16.2 | 55 | 890 | 44.9 | 98.3 | 11.9 |
| W 18 x 50 | 18 | 7.5 | 0.355 | 0.570 | 14.7 | 50 | 800 | 40.1 | 88.9 | 10.7 |
| W 18 x 46 | 18.1 | 6.06 | 0.360 | 0.605 | 13.5 | 46 | 712 | 22.5 | 78.8 | 7.4 |
| W 18 x 40 | 17.9 | 6.02 | 0.315 | 0.525 | 11.8 | 40 | 612 | 19.1 | 68.4 | 6.4 |
| W 18 x 35 | 17.7 | 6 | 0.300 | 0.425 | 10.3 | 35 | 510 | 15.3 | 57.6 | 5.1 |
| W 16×100 | 16.97 | 10.425 | 0.585 | 0.985 | 29.4 | 100 | 1490 | 186 | 175 | 35.7 |
| W 16 x 89 | 16.75 | 10.365 | 0.525 | 0.875 | 26.2 | 89 | 1300 | 163 | 155 | 31.4 |
| W 16 x 77 | 16.52 | 10.295 | 0.455 | 0.760 | 22.6 | 77 | 1100 | 138 | 134 | 26.9 |
| W 16 x 67 | 16.33 | 10.235 | 0.395 | 0.665 | 19.7 | 67 | 954 | 119 | 117 | 23.2 |
| W 16 x 57 | 16.43 | 7.120 | 0.430 | 0.715 | 16.8 | 57 | 758 | 43.1 | 92.2 | 12.1 |
| W 16 x 50 | 16.26 | 7.070 | 0.380 | 0.630 | 14.7 | 50 | 659 | 37.2 | 81 | 10.5 |
| W 16 x 45 | 16.13 | 7.035 | 0.345 | 0.565 | 13.3 | 45 | 586 | 32.8 | 72.7 | 9.3 |
| W 16 x 40 | 16.01 | 6.995 | 0.305 | 0.505 | 11.8 | 40 | 518 | 28.9 | 64.7 | 8.3 |
| W 16 x 36 | 15.86 | 6.985 | 0.295 | 0.430 | 10.6 | 36 | 448 | 24.5 | 56.5 | 7 |
| W 16 x 31 | 15.88 | 5.525 | 0.275 | 0.440 | 9.12 | 31 | 375 | 12.4 | 47.2 | 4.5 |
| W 16 x 26 | 15.69 | 5.5 | 0.250 | 0.345 | 7.68 | 26 | 301 | 9.6 | 38.4 | 3.5 |
| W 14 x 132 | 14.66 | 14.725 | 0.645 | 1.030 | 38.8 | 132 | 1530 | 548 | 209 | 74.5 |
| W 14 x 120 | 14.48 | 14.670 | 0.590 | 0.940 | 35.3 | 120 | 1380 | 495 | 190 | 67.5 |
| W 14×109 | 14.32 | 14.605 | 0.525 | 0.860 | 32 | 109 | 1240 | 447 | 173 | 61.2 |
| W 14 x 99 | 14.16 | 14.565 | 0.485 | 0.780 | 29.1 | 99 | 1110 | 402 | 157 | 55.2 |
| W 14 x 90 | 14.02 | 14.520 | 0.440 | 0.710 | 26.5 | 90 | 999 | 362 | 143 | 49.9 |
| W 14 x 82 | 14.31 | 10.130 | 0.510 | 0.855 | 24.1 | 82 | 882 | 148 | 123 | 29.3 |
| W 14 x 74 | 14.17 | 10.070 | 0.450 | 0.785 | 21.8 | 74 | 796 | 134 | 112 | 26.6 |
| W 14 x 68 | 14.04 | 10.035 | 0.415 | 0.720 | 20.0 | 68 | 723 | 121 | 103 | 24.2 |
| W 14 x 61 | 13.89 | 9.995 | 0.375 | 0.645 | 17.9 | 61 | 640 | 107 | 92.2 | 21.5 |
| W 14 x 53 | 13.92 | 8.060 | 0.370 | 0.660 | 15.6 | 53 | 541 | 57.7 | 77.8 | 14.3 |
| W 14 x 48 | 13.79 | 8.030 | 0.340 | 0.595 | 14.1 | 48 | 485 | 51.4 | 70.3 | 12.8 |
| W 14 x 43 | 13.66 | 7.995 | 0.305 | 0.530 | 12.6 | 43 | 428 | 45.2 | 62.7 | 11.3 |
| W 14 x 38 | 14.10 | 6.770 | 0.310 | 0.515 | 11.2 | 38 | 385 | 26.7 | 54.6 | 7.9 |
| W 14 x 34 | 13.98 | 6.745 | 0.285 | 0.455 | 10.0 | 34 | 340 | 23.3 | 48.6 | 6.9 |
| W 14 x 30 | 13.84 | 6.730 | 0.270 | 0.385 | 8.85 | 30 | 291 | 19.6 | 42.0 | 5.8 |
| W 14 x 26 | 13.91 | 5.025 | 0.255 | 0.420 | 7.69 | 26 | 245 | 8.9 | 35.3 | 3.5 |
| W 14 x 22 | 13.74 | 5 | 0.230 | 0.335 | 6.49 | 22 | 199 | 7 | 29.0 | 2.8 |
| W 12 x 136 | 13.41 | 12.4 | 0.79 | 1.250 | 39.9 | 136 | 1240 | 398 | 186 | 64.2 |
| W 12 x 120 | 13.12 | 12.32 | 0.71 | 1.105 | 35.3 | 120 | 1070 | 345 | 163 | 56.0 |
| W 12×106 | 12.89 | 12.22 | 0.61 | 0.990 | 31.2 | 106 | 933 | 301 | 145 | 49.3 |
| W 12 x 96 | 12.71 | 12.16 | 0.55 | 0.900 | 28.2 | 96 | 833 | 270 | 131 | 44.4 |
| W 12 x 87 | 12.53 | 12.125 | 0.515 | 0.810 | 25.6 | 87 | 740 | 241 | 118 | 39.7 |
| W 12 x 79 | 12.38 | 12.08 | 0.47 | 0.735 | 23.2 | 79 | 662 | 216 | 107 | 35.8 |
| W 12 x 72 | 12.25 | 12.04 | 0.43 | 0.670 | 21.1 | 72 | 597 | 195 | 97.4 | 32.4 |
| W 12 x 65 | 12.12 | 12 | 0.39 | 0.605 | 19.1 | 65 | 533 | 174 | 87.9 | 29.1 |
| W 12 x 58 | 12.19 | 10.01 | 0.36 | 0.640 | 17.0 | 58 | 475 | 107 | 78 | 21.4 |
| W 12 x 53 | 12.06 | 9.995 | 0.345 | 0.575 | 15.6 | 53 | 425 | 95.8 | 70.6 | 19.2 |
| W 12 x 50 | 12.19 | 8.08 | 0.37 | 0.640 | 14.7 | 50 | 394 | 56.3 | 64.7 | 13.9 |
| W 12 x 45 | 12.06 | 8.045 | 0.335 | 0.575 | 13.2 | 45 | 350 | 50.0 | 58.1 | 12.4 |
| W 12 x 40 | 11.94 | 8.005 | 0.295 | 0.515 | 11.8 | 40 | 310 | 44.1 | 51.9 | 11.0 |
| W 12 x 35 | 12.50 | 6.56 | 0.3 | 0.520 | 10.3 | 35 | 285 | 24.5 | 45.6 | 7.5 |
| W 12 x 30 | 12.34 | 6.52 | 0.26 | 0.440 | 8.8 | 30 | 238 | 20.3 | 38.6 | 6.2 |
| W 12 x 26 | 12.22 | 6.490 | 0.23 | 0.380 | 7.7 | 26 | 204 | 17.3 | 33.4 | 5.3 |
| W 12 x 22 | 12.31 | 4.03 | 0.26 | 0.425 | 6.5 | 22 | 156 | 4.7 | 25.4 | 2.3 |
| W 12 x 19 | 12.16 | 4.005 | 0.235 | 0.350 | 5.6 | 19 | 130 | 3.8 | 21.3 | 1.9 |
| W 12 x 16 | 11.99 | 3.990 | 0.22 | 0.265 | 4.7 | 16 | 103 | 2.8 | 17.1 | 1.4 |
| W 12 x 14 | 11.91 | 3.970 | 0.2 | 0.225 | 4.2 | 14 | 88.6 | 2.4 | 14.9 | 1.2 |
| W 10 x 112 | 11.36 | 10.415 | 0.755 | 1.250 | 32.9 | 112 | 716 | 236 | 126 | 45.3 |
| W 10×100 | 11.1 | 10.340 | 0.680 | 1.1120 | 29.4 | 100 | 623 | 207 | 112 | 40.0 |
| W 10 x 88 | 10.84 | 10.265 | 0.605 | 0.990 | 25.9 | 88 | 534 | 179 | 98.5 | 34.8 |
| W 10 x 77 | 10.60 | 10.190 | 0.530 | 0.870 | 22.6 | 77 | 455 | 154 | 85.9 | 30.1 |
| W 10 x 68 | 10.40 | 10.130 | 0.470 | 0.770 | 20.0 | 68 | 394 | 134 | 75.7 | 26.4 |
| W 10 x 60 | 10.22 | 10.080 | 0.420 | 0.680 | 17.6 | 60 | 341 | 116 | 66.7 | 23.0 |
| W 10 x 54 | 10.09 | 10.030 | 0.370 | 0.615 | 15.8 | 54 | 303 | 103 | 60.0 | 20.6 |
| W 10 x 49 | 9.98 | 10 | 0.340 | 0.560 | 14.4 | 49 | 272 | 93.4 | 54.6 | 18.7 |
| W 10 x 45 | 10.10 | 8.020 | 0.350 | 0.620 | 13.3 | 45 | 248 | 53.4 | 49.1 | 13.3 |
| W 10 x 39 | 9.92 | 7.985 | 0.315 | 0.530 | 11.5 | 39 | 209 | 45.0 | 42.1 | 11.3 |
| W 10 x 33 | 9.73 | 7.960 | 0.290 | 0.435 | 9.71 | 33 | 170 | 36.6 | 35.0 | 9.2 |
| W 10 x 30 | 10.47 | 5.81 | 0.3 | 0.510 | 8.84 | 30 | 170 | 16.7 | 32.4 | 5.8 |
| W 10 x 26 | 10.33 | 5.770 | 0.26 | 0.440 | 7.6 | 26 | 144 | 14.1 | 27.9 | 4.9 |
| W 10 x 22 | 10.17 | 5.750 | 0.240 | 0.360 | 6.5 | 22 | 118 | 11.4 | 23.2 | 4 |
| W 10 x 19 | 10.24 | 4.020 | 0.250 | 0.395 | 5.6 | 19 | 96.3 | 4.3 | 18.8 | 2.1 |
| W 10 x 17 | 10.11 | 4.010 | 0.240 | 0.330 | 5 | 17 | 81.9 | 3.6 | 16.2 | 1.8 |
| W 10 x 15 | 9.99 | 4 | 0.230 | 0.270 | 4.4 | 15 | 68.9 | 2.9 | 13.8 | 1.5 |
| W 10 x 12 | 9.87 | 3.960 | 0.190 | 0.210 | 3.5 | 12 | 53.8 | 2.2 | 10.9 | 1.1 |
| W 8 x 67 | 9.00 | 8.280 | 0.570 | 0.935 | 19.7 | 67 | 272 | 88.6 | 60.4 | 21.4 |
| W 8 x 58 | 8.75 | 8.220 | 0.510 | 0.810 | 17.1 | 58 | 228 | 75.1 | 52.0 | 18.3 |
| W 8 x 48 | 8.5 | 8.110 | 0.400 | 0.685 | 14.1 | 48 | 184 | 60.9 | 43.3 | 15.0 |
| W 8 x 40 | 8.25 | 8.070 | 0.360 | 0.560 | 11.7 | 40 | 146 | 49.1 | 35.5 | 12.2 |
| W 8 x 35 | 8.12 | 8.020 | 0.310 | 0.495 | 10.3 | 35 | 127 | 42.6 | 31.2 | 10.6 |
| W 8 x 31 | 8.00 | 7.995 | 0.285 | 0.435 | 9.1 | 31 | 110 | 37.1 | 27.5 | 9.3 |
| W 8 x 28 | 8.06 | 6.535 | 0.285 | 0.465 | 8.3 | 28 | 98.0 | 21.7 | 24.3 | 6.6 |
| W 8 x 24 | 7.93 | 6.495 | 0.245 | 0.400 | 7.1 | 24 | 82.8 | 18.3 | 20.9 | 5.6 |
| W 8 x 21 | 8.28 | 5.270 | 0.250 | 0.400 | 6.2 | 21 | 75.3 | 9.8 | 18.2 | 3.7 |
| W 8 x 18 | 8.14 | 5.250 | 0.230 | 0.330 | 5.3 | 18 | 61.9 | 8 | 15.2 | 3 |
| W 8 x 15 | 8.11 | 4.015 | 0.245 | 0.315 | 4.4 | 15 | 48.0 | 3.4 | 11.8 | 1.7 |
| W 8 x 13 | 7.99 | 4 | 0.230 | 0.255 | 3.8 | 13 | 39.6 | 2.7 | 9.9 | 1.4 |
| W 8×10 | 7.89 | 3.940 | 0.170 | 0.205 | 2.9 | 10 | 30.8 | 2.1 | 7.8 | 1.1 |
| W 6 x 25 | 6.38 | 6.080 | 0.320 | 0.455 | 7.3 | 25 | 53.4 | 17.1 | 16.7 | 5.6 |
| W 6 x 20 | 6.20 | 6.020 | 0.260 | 0.365 | 5.9 | 20 | 41.4 | 13.3 | 13.4 | 4.4 |
| W 6 x 16 | 6.28 | 4.030 | 0.260 | 0.405 | 4.7 | 16 | 32.1 | 4.4 | 10.2 | 2.2 |
| W 6 x 15 | 5.99 | 5.990 | 0.230 | 0.260 | 4.4 | 15 | 29.1 | 9.3 | 9.7 | 3.1 |
| W 6 x 12 | 6.03 | 4 | 0.230 | 0.280 | 3.6 | 12 | 22.1 | 3 | 7.3 | 1.5 |
| W 6 x 9 | 5.90 | 3.940 | 0.170 | 0.215 | 2.7 | 9 | 16.4 | 2.2 | 5.6 | 1.1 |
| W 5 x 19 | 5.15 | 5.030 | 0.270 | 0.430 | 5.5 | 19 | 26.2 | 9.1 | 10.2 | 3.6 |
| W 5 x 16 | 5.01 | 5 | 0.240 | 0.360 | 4.7 | 16 | 21.3 | 7.5 | 8.5 | 3 |
| W 4 x 13 | 4.16 | 4.060 | 0.280 | 0.345 | 3.8 | 13 | 11.3 | 3.9 | 5.5 | 1.9 |
- 1 cm4 = 10-8 m = 104 mm
- 1 in4 = 4.16×105 mm4 = 41.6 cm4
- 1 cm3 = 10-6 m = 103 mm
Calculate Loads
- Beams - Supported at Both Ends - Continuous and Point Loads
- Beams - Fixed at One End and Supported at the Other - Continuous and Point Loads
- Beams - Fixed at Both Ends - Continuous and Point Loads
The standard method for specifying the dimensions of a American Wide Flange Beam is for example W 6 x 25, which is 6 inches deep with a weight of 25 lb/ft.
I-shaped cross-section beams:
- Britain : Universal Beams (UB) and Universal Columns (UC)
- Europe : IPE. HE. HL. HD and other sections
- US : Wide Flange (WF) and H sections
Insert W beams to your 3D Sketchup model with the Engineering ToolBox Sketchup Extension
• Beams and Columns
• Mechanics
American Standard Beams - S Beam
American Standard Steel Channels: Weight, Dimensions & Properties
American Wide Flange Steel Beams: Dimensions and Properties (ASTM A6 in Metric)
Area Moment of Inertia - Typical Cross Sections II
Area Moment of Inertia, Moment of Inertia for an Area or Second Moment of Area for typical cross section profiles.
Area Moment of Inertia with Definitions, Formulas & Calculator
Explore the area moment of inertia (second moment of area) with detailed formulas, calculation tools, and reference tables for common shapes. Essential for structural and mechanical engineering applications.
Beams Fixed at Both Ends with Continuous and Point Loads: Load & Deflection Formulas
Drawbridge - Force and Moment vs. Elevation
Calculate the acting forces and moments when elevating drawbridges or beams.
Euler Column Buckling: Formula, Theory & Calculator
Calculate buckling of columns.
HE-A Steel Beams
HE-B Steel Beams
HE-M Steel Beams
Properties of HE-M profile steel beams.
Normal Flange I-Beams
Square Hollow Structural Sections (HSS) – Sizes, Strength & Specifications
Steel Angles - Equal Legs
Steel Angles - Unequal Legs
Steel Flats - Weights
Steel Pipe Columns - Allowable Loads
Allowable concentric loads for steel pipe columns.
Steel Plate Weight Guide: Calculator & Data Table
Trusses
Common types of trusses.
W Steel Beams - Allowable Uniform Loads
Allowable uniform loads.
Weight of Beams - Stress and Strain
Stress and deformation of vertical beams due to own weight.
