Nominal Pipe Diameter (inches) | Wall Thickness (inches) | Effective Length of Column (feet) | |||||||
6 | 8 | 10 | 12 | 14 | 16 | 18 | 20 | ||
Allowable Concentric Loads (103 lbf) | |||||||||
3 | 0.300 | 52 | 45 | 37 | 28 | 21 | 16 | 12 | |
3 1/2 | 0.318 | 66 | 59 | 51 | 43 | 33 | 25 | 20 | 16 |
4 | 0.337 | 81 | 75 | 67 | 59 | 49 | 39 | 31 | 25 |
5 | 0.375 | 118 | 111 | 103 | 95 | 86 | 76 | 65 | 54 |
6 | 0.432 | 166 | 159 | 151 | 142 | 132 | 122 | 111 | 99 |
8 | 0.500 | 259 | 251 | 243 | 234 | 224 | 214 | 203 | 191 |
10 | 0.500 | 332 | 325 | 318 | 309 | 301 | 291 | 281 | 271 |
12 | 0.500 | 400 | 394 | 387 | 379 | 371 | 363 | 353 | 344 |
Note that the effective column length depends on the column configuration. The values above is valid for columns with rotation free and translation fixed in both ends - equal to correction factor k = 1 in the Euler Column Formula.
Estimate concrete volume required for concrete columns.
Calculate buckling of columns.
Safe loads for wood columns.
