Online Beam Support Force Calculator
The calculator below can be used to calculate the support forces - R1 and R2 - for beams with up to 6 asymmetrically loads.
For a beam in balance loaded with weights (or other load forces) the reactions forces - R - at the supports equals the load forces - F. The force balance can be expressed as
F1 + F2 + .... + Fn = R1 + R2                           (1)
F = force from load (N, lbf)
R = force from support (N, lbf)
In addition for a beam in balance the algebraic sum of moments equals zero. The moment balance can be expressed as
F1 af1 + F2 af2 + .... + Fn afn = R ar1 + R ar2                               (2)
a = the distance from the force to a common reference - usually the distance to one of the supports (m, ft)
Example - A beam with two symmetrical loads
A 10 m long beam with two supports is loaded with two equal and symmetrical loads F1 and F2 , each 500 kg. The support forces F3 and F4 can be calculated
(500 kg) (9.81 m/s2) + (500 kg) (9.81 m/s2) = R1 + R2
R1 + R2 = 9810 N
         = 9.8 kN
Note! Load due to the weight of a mass - m - is mg Newton's - where g = 9.81 m/s2.
With symmetrical and equal loads the support forces also will be symmetrical and equal. Using
R1 = R2
the equation above can be simplified to
R1 = R2 = (9810 N) / 2
    = 4905 N
    = 4.9 kN
Example - A beam with two not symmetrical loads
A 10 m long beam with two supports is loaded with two loads, 500 kg is located 1 m from the end (R1), and the other load of 1000 kg is located 6 m from the same end. The balance of forces can be expressed as
(500 kg) (9.81 m/s2) + (1000 kg) (9.81 m/s2) = R1 + R2
R1 + R2 = 14715 N
       = 14.7 kN
The algebraic sum of moments (2) can be expressed as
(500 kg) (9.81 m/s2) (1 m) + (1000 kg) (9.81 m/s2) (6 m) =?R1 (0 m) + R2 (10 m)
R2 = 6377 (N)
    = 6.4 kN
F3 can be calculated as:
R1= (14715 N) - (6377 N)
    = 8338 N
    = 8.3 kN
Beams and Columns
Mechanics
Statics
Aluminum I-Beams
Dimensions and static properties of aluminum I-beams - Imperial units.
American Standard Beams - S Beam
American Standard Steel C Channels
American Wide Flange Beams
Beams - Fixed at Both Ends - Continuous and Point Loads
Beams - Supported at Both Ends - Continuous and Point Loads
Cantilever Beams - Moments and Deflections
Continuous Beams - Moment and Reaction Support Forces
Moments and reaction support forces with distributed or point loads.
Drawbridge - Force and Moment vs. Elevation
Calculate the acting forces and moments when elevating drawbridges or beams.
Equilibrant Force
The force required to keep a system of forces in equilibrium.
HE-A Steel Beams
HE-B Steel Beams
HE-M Steel Beams
Properties of HE-M profile steel beams.
Normal Flange I-Beams
Square Hollow Structural Sections - HSS
Steel Angles - Equal Legs
Steel Angles - Unequal Legs
Steel Pipe Columns - Allowable Loads
Allowable concentric loads for steel pipe columns.
Triangle
Triangle analytical geometry.
Trusses
Common types of trusses.
W-Beams - American Wide Flange Beams
Weight of Beams - Stress and Strain
Stress and deformation of vertical beams due to own weight.
