Equilibrant Force
The force required to keep a system of forces in equilibrium is called the equilibriant of the system.
In the example above the two forces F1 and F2 can be added to F(1,2)
The equilibrant E acting in the opposite direction of F(1,2) keeps the system in balance.
Mechanics
Statics
Bodies Moving on Inclined Planes - Acting Forces
Required forces to move bodies up inclined planes.
Bollard Forces
Friction, load and effort forces acting in ropes turned around bollards.
Buoyancy
Buoyancy is the resultant force acting on a submerged body.
Centripetal and Centrifugal Acceleration Force
Forces due to circular motion and centripetal / centrifugal acceleration.
Force
Force Ratio
The force ratio is the load force versus the effort force.
Pulleys
Pulleys, blocks and tackles.
Vector Addition
Online vector calculator - add vectors with different magnitude and direction - like forces, velocities and more.
