Buoyancy
Buoyancy is defined as the tendency of a body to float or rise when submerged in a fluid. The resultant force acting on a submerged body by the fluid is called the buoyant force and can be expressed as
F = V γ
= V ρ g (1)
F = buoyant force (N)
V = body volume (m3)
γ = ρ g = specific weight of fluid (N/m3)
ρ = density of fluid (kg/m3)
g = acceleration of gravity (= 9.81 m/s2)
The buoyant force acts upwards.
Archimedes' principle indicates that
"the upward buoyant force that is exerted on a body fully or partially submerged in a fluid - equals to the weight of the fluid that the body displaces"
- if the body weighs more than the fluid - it sinks
- if the body weighs less than the fluid - it floats
Example - Buoyant Force acting on a Floating Box
A plastic box with length 0.3 m and width 0.4 m is submerged 0.1 m into water. The water density is 1000 kg/m 3.
The buoyant force acting on the box can be calculated with (1)
F = (0.3 m) (0.4 m) (0.1 m) ( 1000 kg/m3) ( 9.81 m/s2)
= 119 N
Center of Gravity
A body and the center of gravity.
Stability - the center of gravity vs. the center of buoyancy.
Equilibrant Force
The force required to keep a system of forces in equilibrium.
Hot Air Balloon Lifting Force Calculator
Calculate the lifting force of a hot air balloon based on temperature difference, air density, and balloon volume. Includes formulas, explanations, and practical applications for aeronautics and physics.
Hydrostatic Force acting on Submerged Surface
Calculate the thrust force acting on a submerged surface.
