Center of Gravity
The "center of gravity" for a volume, an area or a line - is the point at which the body - if suspended - would be in balance.
For a symmetrical body in a uniform material - the center of gravity would be in the geometric center.
Perimeter
The center of gravity is the center of the circle inscribed in triangle ABC (middle points of the sides of the triangle).
The distance d can be calculated as
d = h (b + c) / 2 (a + b + c)                                (1)
Triangle
The center of gravity of a triangle is at the intersection of lines BE and AD. The distance a can be calculated as
a = h / 3                               (2)
Parallelogram
The center of gravity of a parallelogram is at the intersection of the diagonals.
Trapezoid
The center of gravity of a trapezoid can be estimated by dividing the trapezoid in two triangles. The center of gravity will be in the intersection between the middle line CD and the line between the triangles centers of gravity.
Two Bodies
The center of gravity of two bodies can be calculated as
b = Q a / (P + Q)                     (3a)
c = P a / (P + Q)                     (3b)
Q, P = weight or mass of the bodies (N, kg, lb, slugs)
Mathematics
Mechanics
Miscellaneous
Statics
Acceleration of gravity and Newton's Second Law - SI and Imperial units.
Area Moment of Inertia with Definitions, Formulas & Calculator
Explore the area moment of inertia (second moment of area) with detailed formulas, calculation tools, and reference tables for common shapes. Essential for structural and mechanical engineering applications.
Buoyancy
Buoyancy is the resultant force acting on a submerged body.
Center Mass
Calculate position of center mass.
Stability - the center of gravity vs. the center of buoyancy.
Force
Hydrostatic Force acting on Submerged Surface
Calculate the thrust force acting on a submerged surface.
Mass vs Weight
Pythagorean Theorem
Verifying square corners.
Regular Polygons
Areas of regular polygons - polygons with 3 to 12 sides.
Right Angled Triangle
Right angled triangle equations.
Section Modulus - Unit Converter
Convert between Elastic Section Modulus units.
Triangle
Triangle analytical geometry.
Universal Gravitational Law
Gravitational attraction between two objects vs. mass of the objects and the distance between them.
