Center Mass
A coordinate system for determining center of mass:
The position of center mass can calculated as
Rx = (ma xa + mb xb) / (ma + mb)
     = (mb / (ma + mb)) d                                (1)
Rx = x-coordinate for the center of mass
Mechanics
Statics
Area Moment of Inertia - Typical Cross Sections I
Area Moment of Inertia - Typical Cross Sections II
Area Moment of Inertia, Moment of Inertia for an Area or Second Moment of Area for typical cross section profiles.
Cantilever Beams - Moments and Deflections
Center of Gravity
A body and the center of gravity.
Stability - the center of gravity vs. the center of buoyancy.
Force
Mass Moment of Inertia
The Mass Moment of Inertia vs. mass of object, it's shape and relative point of rotation - the Radius of Gyration.
Mass vs. Weight
