Pythagorean Theorem
The Pythagorean theorem often used
  • to verify if a corner is square (90 degrees)
and can be expressed as
C2 = A2 + B2                         (1)
(1) can be transformed to express the length of hypotenuse C as
C = (A2 + B2)1/2                                     (1b)
Example - Determine the length of the Hypotenuse  - C
With A = 5 m and B = 10 m - the length of the hypotenuse - C - can be calculated as
C = ((5 m)2 + (10 m)2)1/2
   = 11.2 m
Squaring a Corner
The angle is square (90 degrees) if
  • A = 3 (m, ft)
  • B = 4 (m, ft)
  • C = 5 (m, ft)
Hypotenuse Calculator
Calculate square triangle hypotenuse - C - length:
The Sine Rule
A / sin(a) = B / sin(b) = C / sin(c)                          (2)
Mathematics
Cartesian Coordinate System - Distance and Intermediate Position Between Two Points
Distance and intermediate position between two point in a cartesian x and y coordinate system.
Center of Gravity
A body and the center of gravity.
Centroids of Plane Areas
The controid of square, rectangle, circle, semi-circle and right-angled triangle.
Equal Areas - Circles vs. Squares
Radius and side lengths of equal areas, circles and squares.
Geometric Shapes - Areas
Areas, diagonals and more - of geometric figures like rectangles, triangles, trapezoids ..
Hyperbolic Functions
Exponential functions related to the hyperbola.
Law of Cosines
One side of a triangle when the opposite angle and two sides are known.
Law of Sines
Calculate the angles in a generic triangle.
Law of Tangents
Triangles and law of tangents.
Numbers - Squares, Cubes and Roots
Numbers - squares, cubes, square roots and cube roots.
Oblique Triangle
Calculate oblique triangles.
Polar vs. Cartesian Coordinates
Convert between Cartesian and Polar coordinates.
Regular Polygons
Areas of regular polygons - polygons with 3 to 12 sides.
Right Angled Triangle
Right angled triangle equations.
Triangle
Triangle analytical geometry.
Trigonometric Functions
Sine, cosine and tangent - the natural trigonometric functions.
Vector Addition
Online vector calculator - add vectors with different magnitude and direction - like forces, velocities and more.
