Polar vs. Cartesian Coordinates
In the Cartesian system the coordinates are perpendicular to one another with the same unit length on both axes.
2D Cartesian coordinates in the figure below: (2,3)
A Polar coordinate system is determined by a fixed point, a origin or pole, and a zero direction or axis. Each point is determined by an angle and a distance relative to the zero axis and the origin.
Polar coordinates in the figure above: (3.6, 56.31)
Polar coordinates can be calculated from Cartesian coordinates like
r = (x2 + y2)1/2                            (1)
r = distance from origin to the point
x = Cartesian x-coordinate
y = Cartesian y-coordinate
θ = atan(y / x)
   = tan-1(y / x)                          (2)
θ = angle relative to the zero axis (degrees)
Cartesian coordinates can be calculated from Polar coordinates like
x = r cos(θ)                           (3)
y = r sin(θ)                           (4)
Cartesian to Polar Coordinates Converter
Polar to Cartesian Coordinates Converter
Mathematics
Area Survey App
Online app that can be used to make an exact plot of a surveyed area - like a room, a property or any 2D shape.
Cartesian Coordinate System - Distance and Intermediate Position Between Two Points
Distance and intermediate position between two point in a cartesian x and y coordinate system.
Circle Equation
The equation for a circle
Complex Numbers
Complex numbers are used in alternating current theory and mechanical vector analysis.
Differential Calculus
Derivatives and differentiation expressions.
Distance between 3D Points
Distance between two points in a three dimension x, y and z coordinate system - online calculator.
Latitude and Longitude Converter: Convert Between Degrees, Minutes, Seconds, and Decimal Units
Convert between Degrees, Minutes and Seconds and Decimal Units (or vice versa).
Minutes to Decimal Hours Conversion: Chart & Calculator
Convert minutes to descimal hours.
Pythagorean Theorem
Verifying square corners.
Radians vs. Degrees - Definition and Conversions
Standard Differentials and Integrals
Equations for differentials and integrals.
Steradian
A unit of solid-angle measure in the International System of Units (SI)
Taylor Series
Function as an infinite sum of terms.
Trench Excavation
Estimate trench excavation - online calculator.
Triangle
Triangle analytical geometry.
UTM to Latitude and Longitude Converter: Convert UTM Coordinates to Geographic Coordinates
Free online UTM to Latitude and Longitude coordinates converter.
