Latitude and Longitude Converter
Convert between Latitude and Longitude in Degrees, Minutes and Seconds - and Decimal units.
Decimal Degrees Units to Degrees, Minutes and Seconds Converter
Latitude : deg min sec
Longitude: deg min sec
Degrees, Minutes and Seconds to Decimal units Converter
Convert to decimal degrees.
Latitude : (degrees)
Longitude: (degrees)
Miscellaneous
Acceleration of Gravity vs. Latitude and Elevation
Acceleration of gravity due to latitude and elevation above sea level.
Builder's to Surveyor's Measurements
Convert builder's measurements to surveyor's measurements.
Distance between 3D Points
Distance between two points in a three dimension x, y and z coordinate system - online calculator.
Minutes to Decimal Hours
Convert minutes to descimal hours.
Minutes vs. Degrees - Converting Chart
Convert from minutes to degrees.
Polar vs. Cartesian Coordinates
Convert between Cartesian and Polar coordinates.
Radians vs. Degrees
Satellites in Orbit
Orbital and escape velocity for geostationary satellites.
Solar Radiation - Daily Surface Energy
Daily surface energy from solar radiation.
Unit Factor Method
UTM to Latitude and Longitude Converter
Free online UTM to Latitude and Longitude coordinates converter.
