Unit Factor Method
Unit Factor Method
Unit converting from one system to an other can be done with the unit factor method - also called dimensional analysis.
The relationship between two different units can be expressed as
$$ 1 (u_1) = x (u_2) \tag{1} $$
u1 = unit 1
u2 = unit 2
x = converting factor from u2 to u1
Example - inches vs. mm
$$ 1 (in) = 25.4 (mm) $$
Dividing the relationship (1) with the two sides - two unit factors for the relationship can be expressed as
$$ \frac {1 (u_1) }{ x (u_2)} = 1 \tag{2} $$
$$ \frac {x (u_2) }{ 1 (u_1)} = 1 \tag{3} $$
$$ \frac {1 (in) }{ 25.4 (mm)} = 1 $$
$$ \frac {25.4 (mm) }{ 1 (in)} = 1 $$
Converting a value from one unit to an other can then simply by done by multiplying both sides of eq. 2 or 3 with the value.
$$ \frac {1 (u_1) \ a (u_2)}{ x (u_2)} = a (u_2) \tag{2a} $$
$$ \frac {x (u_2) \ b (u_1)}{ 1 (u_1)} = b (u_1) \tag{3a} $$
Example - Converting 10 mm to inches
$$ \frac {1 (in) \ 10 (mm)}{ 25.4 (mm)} = 10 (mm) $$
$$ 0.39 (in) = 10 (mm) $$
Factor-label Method
The factor-label method is an sequential combination of conversion factors where numerator and denominator of the conversion factor fractions can be cancelled out to achieve a desired set of dimensional units.
$$ \frac {1 (u_1) }{ x (u_2)} \ \frac {y (u_2) }{ 1 (u_3)} \ \frac {1 (u_3) }{ z (u_4)} = \frac {y (u_1) }{ x z (u_4)} \tag{4} $$
Example - Converting 2.5 feet to mm
Th unit factor for mm to feet can be calculated using eq. 4 as:
$$ \frac {25.4 (mm) }{ 1 (in)} \ \frac {12 (in) }{ 1 (ft)} = 304.8 (\frac {mm}{ft}) $$
10 mm can be converted to feet as
$$ 308.5 (mm/ft) \ 2.5 (ft) = \underline{771.3} (mm) $$
• Basics
Acceleration Units Converter
Converting between units of acceleration.
Angle Converter
Converting between angle units.
Area Moment of Inertia Converter
Convert between Area Moment of Inertia units.
Area Units Converter
Convert between units of area.
Concentration Units Converter
Calculator and formulas for conversion between different units of concentration: Molarity, molality, mole fraction, weight percent of solute and grams of solute per liter of solution - descriptive terms for solubility.
Density Converter
Latitude and Longitude Converter: Convert Between Degrees, Minutes, Seconds, and Decimal Units
Convert between Degrees, Minutes and Seconds and Decimal Units (or vice versa).
Length - Online Unit Converter
Convert between length units like meters, feet, inches, nautical miles and more.
Oil Viscosity Converter
Convert between commonly used oil viscosity units.
Pressure to Head Unit Converter
Pressure vs. head units - like lb/in2, atm, inches mercury, bars, Pa and more.
Convert between pressure units like Pa, bar, atmosphere, pound square feet, psi and more.
Section Modulus - Unit Converter
Convert between Elastic Section Modulus units.
Common converting units for Acceleration, Area, Density, Energy, Energy per unit mass, Force, Heat flow rate, Heat flux, Heat generation per unit volume and many more.
UTM to Latitude and Longitude Converter: Convert UTM Coordinates to Geographic Coordinates
Free online UTM to Latitude and Longitude coordinates converter.
Vacuum - Pressure Units Converter
Converting between vacuum units like % vacuum - mm Mercury - psi - torr - micron - kPa.
Velocity Units - Online Converter
Convert between common velocity and speed units.
Velocity Units Converter
Convert between speed and velocity units like m/s, km/h, knots, mph and ft/s.
Volume Units Converter
Convert between common volume units like cubic metre, cubic feet, cubic inches and more.
