Area Units Converter
This calculator can used to convert between commonly used area units.
Basics
Area Survey App
Online app that can be used to make an exact plot of a surveyed area - like a room, a property or any 2D shape.
Centroids of Plane Areas
The controid of square, rectangle, circle, semi-circle and right-angled triangle.
Circles - Circumferences and Areas
Circumferences and areas of circles with diameters in inches.
Circles within a Rectangle - Calculator
Calculate the maximum number of circles within a rectangle - can be used to calculate the numbers of pipes or wires in a conduit or similar.
CM - Circular Mil Area
The circular mil area (CM) unit denotes the cross-sectional size of a wire or a cable.
Elementary Surfaces
Ellipsoid, sphere, hyperboloid, cone and more.
Equal Areas - Circles vs. Squares
Radius and side lengths of equal areas, circles and squares.
Evaporation of water from a water surface - like a swimming pool or an open tank - depends on water temperature, air temperature, air humidity and air velocity above the water surface - online calculator.
Geometric Shapes - Areas
Areas, diagonals and more - of geometric figures like rectangles, triangles, trapezoids ..
Hydraulic Cylinder Area vs. Diameter
Typical hydraulic cylinders and acting area vs. cylinder diameter.
Lengths and Areas vs. Mapping Scales
Convert lengths areas between different mapping scales.
Maximizing Space: Fit Small Rectangles Inside a Larger Rectangle
Pipe and Tubing Formulas
Pipe and Tube Equations - moment of inertia, section modulus, traverse metal area, external pipe surface and traverse internal area - imperial units
Piping Equations
Calculate cross-sectional areas, weight of empty pipes, weight of pipes filled with water, inside and outside surface areas.
Solids - Volumes and Surfaces
The volume and surface of solids like rectangular prism, cylinders, pyramids, cones and spheres - online calculator.
Unit Factor Method
Water Sprinkler Protected Areas and Hazard Classification
Maximum fire sprinkler protected area vs. classification and construction.
