Elementary Surfaces
The simplest of surfaces are the unbound planes. The next complexity are the second degree or quadric surfaces.
Non-degenerate Quadrics
Ellipsoid
x2/a2 + y2/b2 + z2/c2 = 1                       (1)
a, b, c = intrinsic parameters
Sphere
Sphere, a special ellipsoid, can be expressed as
x2 + y2 + z2 = a2                            (2)
a = radius
Hyperboloid of one sheet
x2/a2 + y2/b2 - z2/c2 = 1                            (3)
Hyperboloid of two sheets
x2/a2 + y2/b2 - z2/c2 = -1                            (4)
Quadric Cone
x2/a2 + y2/b2 - z2/c2 = 0                             (5)
Elliptic Paraboloid
x2/a2 + y2/b2 - 2 z = 0                                (6)
a, b = intrinsic parameters
Elliptic Cylinder
x2/a2 + y2/b2 = 1                                (7)
Cylinder
x2 + y2 = a2                                (8)
Hyperbolic Cylinder
x2/a2 - y2/b2 = 1                                 (9)
Parabolic Cylinder
y2 - 2 l x = 0                             (10)
l = intrinsic parameters
Degenerate Quadrics
Parallel Planes
x2 - a2 = 0                             (11)
a = half the distance between the parallel planes
Intersecting Planes
x2/a2 - y2/b2 = 0                          (12)
tan-1(b/a) = half the angle between the intersecting planes
Coincident Planes
x2 = 0                            (13)
Mathematics
Area of Intersecting Circles
Calculate area of intersecting circles
Area Units Converter
Convert between units of area.
Circle - the Chord Lengths when Divided in to Equal Segments
Calculate chord lengths when dividing the circumference of a circle into an equal number of segments.
Circles within a Rectangle - Calculator
Calculate the maximum number of circles within a rectangle - can be used to calculate the numbers of pipes or wires in a conduit or similar.
Elementary Curves
Ellipse, circle, hyperbola, parabola, parallel, intersecting and coincident lines.
Equal Areas - Circles vs. Squares
Radius and side lengths of equal areas, circles and squares.
Hyperbolic Functions
Exponential functions related to the hyperbola.
