Elementary Curves
The simplest of all curves are the straight lines. The next in complexity are the second degree or conics curves.
Non-degenerate Conics
Ellipse
x2 / a2 + y2 / b2 = 1 (1)
a, b = intrinsic parameters
Circle
Circle, a special ellipse, can be expressed as
x2 + y2= a2 (2)
a = radius
Hyperbola
x2 / a2 - y2 / b2 = 1 (3)
Parabola
y2 - 2 l x = 0 (4)
l = intrinsic parameter
Degenerate Conics
Parallel Lines
x2 - a2 = 0 (5)
a = half the distance between the parallel lines
Intersecting Lines
x2 / a2 - y2 / b2 = 0 (6)
tan-1 (b /a) = half the angle between the intersecting lines
Coincident Lines
x2 = 0 (7)
• Mathematics
Area of Intersecting Circles
Calculate area of intersecting circles
Centroids of Plane Areas
The controid of square, rectangle, circle, semi-circle and right-angled triangle.
Circle - the Chord Lengths when Divided in to Equal Segments
Calculate chord lengths when dividing the circumference of a circle into an equal number of segments.
Circle Equation
The equation for a circle
Circles - Circumferences and Areas
Circumferences and areas of circles with diameters in inches.
Circles on the Outside of a Circle
Calculate the numbers of circles on the outside of an inner circle - like the geometry of rollers on a shaft.
Circles within a Rectangle - Calculator
Calculate the maximum number of circles within a rectangle - can be used to calculate the numbers of pipes or wires in a conduit or similar.
Elementary Surfaces
Ellipsoid, sphere, hyperboloid, cone and more.
Equal Areas - Circles vs. Squares
Radius and side lengths of equal areas, circles and squares.
Geometric Shapes - Areas
Areas, diagonals and more - of geometric figures like rectangles, triangles, trapezoids ..
Hexagons and Squares - Diagonal Lengths
Distances between corners for hexagons and squares.
Polynomial Equation of nth Degree
The polynomial nth degree equation.
Radians vs. Degrees - Definition and Conversions
Spherical and Cylindrical Coordinates
3D cylindrical and spherical coordinate systems
