Circles on the Outside of a Circle
The calculator below can be used to calculate the maximum numbers of rollers on a shaft - or - the maximum number of circles on the outside of an inner circle.
The calculator is generic and any kind of units can be used - as long as the same units are used for all values.
Mathematics
Area of Intersecting Circles
Calculate area of intersecting circles
Centroids of Plane Areas
The controid of square, rectangle, circle, semi-circle and right-angled triangle.
Circle - the Chord Lengths when Divided in to Equal Segments
Calculate chord lengths when dividing the circumference of a circle into an equal number of segments.
Circles - Circumferences and Areas
Circumferences and areas of circles with diameters in inches.
Calculate the numbers of circles on the outside of an inner circle - like the geometry of rollers on a shaft.
Circles within a Rectangle - Calculator
Calculate the maximum number of circles within a rectangle - can be used to calculate the numbers of pipes or wires in a conduit or similar.
Elementary Curves
Ellipse, circle, hyperbola, parabola, parallel, intersecting and coincident lines.
Equal Areas - Circles vs. Squares
Radius and side lengths of equal areas, circles and squares.
Geometric Shapes - Areas
Areas, diagonals and more - of geometric figures like rectangles, triangles, trapezoids ..
Length of a Spiral
Calculate the length of a spiral or the length of material contained in a roll.
Maximizing Space: Fit Small Rectangles Inside a Larger Rectangle
Polynomial Equation of nth Degree
The polynomial nth degree equation.
Spherical and Cylindrical Coordinates
3D cylindrical and spherical coordinate systems
Squaring with Diagonal Measurements
A rectangle is square if the lengths of both diagonals are equal.
