The calculator below can be used to estimate the maximum number of small circles that fits into an outer larger circle. The calculator can be used to calculate applications like
- the number of small pipes that fits into a large pipe or tube
- the number of wires possible in a conduit
- the number of fibers that fits in a connector
- and similar applications
Input
- the inside diameter of an outer larger circle (or pipe, tube, conduit, connector), and
- the outside diameters of small circles (or pipes, wires, fiber)
The default values are for a 10 inch pipe with 2 inch smaller pipes - dimensions according ANSI Schedule 40 Steel Pipes.
- Note that the algorithm is quite simple - a circle or more may be added by rearranging the circles in a more sophisticated pattern.
Outside Diameter of a Bundle of Pipes
Tip! - the calculator above can be used to approximate the outside diameter of a bundle of pipes by inserting the small pipe diameter and do an iterative changing of the outside pipe diameter until the number of pipes calculated fits the number of pipes in the bundle.
Example - Outside diameter of a bundle with 30 pc. 1.5 inch pipes. The iterative process can be done like this
Iteration No.e | Input | Calculated | |
Small Pipe Diameter | Large Pipe Diameter | No. of Pipes | |
1 | 1.5 | 10 | 32 |
2 | 1.5 | 9 | 26 |
3 | 1.5 | 9.8 | 31 |
4 | 1.5 | 9.6 | 29 |
5 | 1.5 | 9.7 | 31 |
6 | 1.5 | 9.65 | 30 |
Iteration 6 indicates that the outside diameter of the bundle of pipes is approximately 9.65 inches.
Calculate Maximum Number of Smaller Circles in Larger Circles
- an array with multiple smaller and larger circles
In the boxes below
- add a comma separated list with the sizes of the larger circles
- add a comma separated list with the sizes of the smaller circles
An array with the maximum number of smaller circles within the larger circles will be created.
The default input values above are from ANSI Schedule 40 Steel Pipes.
• Electrical
• Mathematics
• Piping Systems
ANSI Steel Pipe Schedule 40 Chart: Dimensions, Weights & Specifications
Area Units Converter
Convert between units of area.
AWG - American Wire Gauge vs. Circular Mils
AWG vs. diameter mil, circular mil, diameter in mm and area in mm2.
AWG - Wire Gauge Sizes: Current Ratings, Charts, Measurements, and Conversion Guide
Amp ratings vs. US AWG wire gauge.
Circle - the Chord Lengths when Divided in to Equal Segments
Calculate chord lengths when dividing the circumference of a circle into an equal number of segments.
Circle Equation
The equation for a circle
Circles - Circumferences and Areas
Circumferences and areas of circles with diameters in inches.
Circles on the Outside of a Circle
Calculate the numbers of circles on the outside of an inner circle - like the geometry of rollers on a shaft.
Circles within a Rectangle - Calculator
Calculate the maximum number of circles within a rectangle - can be used to calculate the numbers of pipes or wires in a conduit or similar.
Copper and Aluminum Wire - Max Amps vs. Gauge
Maximum current in copper and aluminum wire.
Discrete Data Sets and their Mean, Median and Mode Values
Calculate the arithmetic mean, median and modal values from discrete data sets.
Elementary Curves
Ellipse, circle, hyperbola, parabola, parallel, intersecting and coincident lines.
Elementary Surfaces
Ellipsoid, sphere, hyperboloid, cone and more.
Equal Areas - Circles vs. Squares
Radius and side lengths of equal areas, circles and squares.
Length of a Spiral
Calculate the length of a spiral or the length of material contained in a roll.
Maximizing Space: Fit Small Rectangles Inside a Larger Rectangle
Solving Equations of the First Degree with One Unknown
Equations with one unknown.
Solving First Degree Equations with Two Unknowns
Online calculator and solbing procedure for two equations with two unknowns.
Solving Quadratic Equation with One Unknown
How to solve a quadratic equation.
Squaring with Diagonal Measurements
A rectangle is square if the lengths of both diagonals are equal.
