Copper and Aluminum Wire - Max Amps vs. Gauge
Maximum current in aluminum and copper wire with ambient temperature 86 oF (30 oC):
print Maximum Current in Aluminum and Copper Wire Diagram
Example - Maximum Current in 6 mm2 Aluminum Wire
6 mm2 aluminum wire is somewhere between AWG #9 and #10.  To be on the safe side we use AWG #10 (the smallest one) in the figure above and estimates the maximum current to be approximately 30 amps.
Copper and Aluminum - Max. Current Diagram in Metric Units
Maximum current diagram based on wire size in metric units mm2:
Electrical
AWG Wire Gauge Chart & Table – American Wire Gauge (AWG) Standards
The AWG (American Wire Gauge) wire size chart with detailed specifications on wire diameter, resistance, and ampacity. Find conversions between AWG sizes and metric units for electrical and engineering applications.
Electrical DC Motors - Full-load Currents
Full load amps in 120 and 240 volts electrical DC motors.
Electrical Formulas
Commonly used electrical formulas like Ohms Law and more.
Electrical Motors - Full Load Amps
Full load amps for single and 3-phase 460 volts, 230 volts and 115 volts electric motors.
