Electrical units, amps and electrical wiring, wire gauge and AWG, electrical formulas and motors.
Maximum current in copper and aluminum wire.
Maximum length of 240 V single phase electric wire with max. 2% voltage drop.
Full load amps for single and 3-phase 460 volts, 230 volts and 115 volts electric motors.
