Equal Areas - Circles vs. Squares
The area of a circle can be expressed as
Ac = π r2 (1)
Ac = circle area (m2, ft2)
r = circle radius (m, ft)
The area of a square can be expressed as
As = s2 (2)
As = square area (m2, ft2)
s = side of square (m,ft)
If the area of the circle is equal to the area of the square - then Ac = As and (1) and (2) can be combined to
π r2 = s2 (3)
Radius of Circle - Side of Square is known
r = (s2 / π)1/2 (4)
Side of Square - Radius of a Circle if known
s = (π r2)1/2 (5)
Example - Circle and Square with equal Area
The side length of a square with the same area as a circle with radius 2 m can be calculated as
s = (π (2 m)2)1/2
= 3.54 m
• Mathematics
American vs. British Piping Standards
US American (ASTM) vs. British (BSi) piping standards - specifications, grades and material descriptions.
Area of Intersecting Circles
Calculate area of intersecting circles
Area Survey App
Online app that can be used to make an exact plot of a surveyed area - like a room, a property or any 2D shape.
Area Units Converter
Convert between units of area.
Centroids of Plane Areas
The controid of square, rectangle, circle, semi-circle and right-angled triangle.
Circle Equation
The equation for a circle
Circles - Circumferences and Areas
Circumferences and areas of circles with diameters in inches.
Circles on the Outside of a Circle
Calculate the numbers of circles on the outside of an inner circle - like the geometry of rollers on a shaft.
Circles within a Rectangle - Calculator
Calculate the maximum number of circles within a rectangle - can be used to calculate the numbers of pipes or wires in a conduit or similar.
Elementary Curves
Ellipse, circle, hyperbola, parabola, parallel, intersecting and coincident lines.
Elementary Surfaces
Ellipsoid, sphere, hyperboloid, cone and more.
Geometric Shapes - Areas
Areas, diagonals and more - of geometric figures like rectangles, triangles, trapezoids ..
Hexagons and Squares - Diagonal Lengths
Distances between corners for hexagons and squares.
Length of a Spiral
Calculate the length of a spiral or the length of material contained in a roll.
Maximizing Space: Fit Small Rectangles Inside a Larger Rectangle
Polynomial Equation of nth Degree
The polynomial nth degree equation.
Pythagorean Theorem
Verifying square corners.
Solids - Volumes and Surfaces
The volume and surface of solids like rectangular prism, cylinders, pyramids, cones and spheres - online calculator.
Spherical and Cylindrical Coordinates
3D cylindrical and spherical coordinate systems
Squaring with Diagonal Measurements
A rectangle is square if the lengths of both diagonals are equal.
