Hexagons and Squares - Diagonal Lengths
Hexagon
The distance between the corners in a hexagon as indicated in the figure can be expressed as
Dh = (2 / 3) 31/2 d
     = 1.154701 d                            (1)
Square
The distance between corners - length of diagonal - in a square can be expressed as
Ds = 21/2 d
     = 1.4142 d                            (2)
Example - Distance between Corners in a Hexagon
The distance between corners in a hexagon where d = 0.4 m can be calculated as
Dh = 1.154701 0.4
    = 0.462 m
Mathematics
Centroids of Plane Areas
The controid of square, rectangle, circle, semi-circle and right-angled triangle.
Elementary Curves
Ellipse, circle, hyperbola, parabola, parallel, intersecting and coincident lines.
Equal Areas - Circles vs. Squares
Radius and side lengths of equal areas, circles and squares.
Geometric Shapes - Areas
Areas, diagonals and more - of geometric figures like rectangles, triangles, trapezoids ..
Metric Bolt Heads and Wrench Sizes
ANSI/SO, DIN and JIS bolts.
Regular Polygons
Areas of regular polygons - polygons with 3 to 12 sides.
