Metric Bolt Heads and Wrench Sizes
ANSI/ISO, DIN and JIS metric bolt head and wrench sizes:
| ISO Metric Threaded Bolt (mm) | Spanner or Wrench Size (mm) | Allen Key (mm) | ||
| ANSI/ISO | DIN | JIS | ANSI/ISO | |
| 3 | 5.5 | |||
| 4 | 7 | 7 | 7 | |
| 5 | 8 | 8 | 8 | 4 |
| 6 | 10 | 10 | 10 | 5 |
| 7 | 11 | |||
| 8 | 13 | 13 | 12 | 6 |
| 10 | 15, 16 | 17 | 14 | 8 |
| 12 | 18 | 19 | 17 | 10 |
| 14 | 21 | 22 | 19 | |
| 16 | 24 | 24 | 22 | 14 |
| 18 | 27 | |||
| 20 | 30 | 30 | 17 | |
| 24 | 36 | 19 | ||
- ANSI B18.2.3.9M Metric Heavy Hex Flange Screws
- ISO 4228 Spanners and wrenches -- Spline drive ends for power socket wrenches
- ISO 724 - Metric Threads
An Allen key, Allen wrench or hex key is a tool used to drive bolts and screws with hexagonal sockets in their heads.
• Fasteners
Hardwood and Softwoods - Recommended Drill Bit Speeds
Hardwood and softwood drill speed chart.
Hexagons and Squares - Diagonal Lengths
Distances between corners for hexagons and squares.
Metric Threads - Clearance Holes and Tapping Drill Sizes
Recommended clearance holes and drill tap sizes.
Screws - Metric vs. Inches
Metric versus Imperial equivalent screw dimensions.
Steel Bolts - ASTM Grades
Steel Bolts - SAE Grades
T-Slots and T-Nuts - Metric Sizes
Standard metric T-slots and T-nuts.
Threaded Bolts - Stress Area
Threaded bolts tensile stress area.
Torque Specifications for Metric Bolts: Maximum Values & Tables
U.S. Bolts - Head and Wrench Sizes
Hex Bolt, Lag Bolt, Square Bolt and Heavy Hex Bolt.
Unified Thread Standards: UNC & UNF Size Charts & Specifications
US Hex Bolts - Inches
ANSI/ASME B18.2.1 Dimensions of Hex Bolts - Imperial units.
US Hex Bolts - Metric
US Machine Screws - Dimensions
Machine screw diameters.
