Size | s2 (mm) | t2 (mm) | a2 (mm) | h2 (mm) |
M4 | 5 | 9 | 2.5 | 6 |
M5 | 6 | 10 | 4 | 8 |
M6 | 8 | 13 | 6 | 10 |
M8 | 10 | 15 | 6 | 12 |
M10 | 12 | 18 | 7 | 16 |
M12 | 14 | 22 | 8 | 19 |
M16 | 18 | 28 | 10 | 25 |
ANSI/SO, DIN and JIS bolts.
