ISO 724 - Metric Threads
ISO 724 specifies basic dimensions of metric threads in accordance with ISO 261. Dimensions refer to the basic profile in accordance with ISO 68.
The pitch varies from coarse to extra fine with up to 5 different pitches for some dimensions. The thread angle is 60o and the thread depth is 0.614 x pitch.
Metric Threads - Coarser Threads
The table below indicates some of the most used coarse threads up to size M 68. Note that the ISO 724 standard specifies threads up to M 300. The table below is not complete.
ISO 724 - Metric Coarser Threads
Size - Nominal Diameter
(mm)
Pitch1)
(mm)
Clearance Drill
(mm)
Tap Drill
(mm)
Tensile Stress Area
(mm2)
M 1.6 0.35 1.8 1.25
M 2 0.40 2.4 1.60
M 2.5 0.45 2.90 2.00
M 3 0.50 3.40 2.50
M 3.5 0.60 3.90 2.90
M 4 0.70 4.50 3.30 8.78
M 5 0.80 5.50 4.20 14.2
M 6 1.00 6.60 5.00 20.1
M 8 1.25 9.00 6.80 36.6
M 10 1.50 12.00 8.50 58.0
M 12 1.75 14.00 10.20 84.3
M 14 2.00 16.00 12.00
M 16 2.00 18.00 14.00 157
M 20 2.50 22.00 17.50 245
M 22 2.50 25.00 19.50
M 24 3.00 27.00 21.00 353
M 27 3.00 30.00 24.00
M 30 3.50 33.00 26.50 561
M 36 4.00 40.00 32.00 817
M 42 4.50 46.00 37.50 1120
M 48 5.00 53.00 43.00 1470
M 56 5.50 62.00 50.50 2030
M 64 6.00 70.00 58.00 2680
M 68 6.00 74.00 62.00
1) For metric threads pitch is the distance between threads.
Download and print metric coarce threads clearance and tap drill chart
Metric Threads - Finer Threads
It is common to designate metric fine threads with the capital M plus an indication to their nominal outer diameter and their pitch:
M size x pitch
Example:
M 10 x 1.5
The table below indicates the typically used finer threads up to size M 100. Note that the ISO 724 standard specifies threads up to M 300.
ISO 724 - Metric Finer Threads
(mm)
Pitch1)
(mm)
Tap Drill
(mm)
Tensile Stress Area
(mm2)
M 1.0 x 0.2 0.20 0.80
M 1.1 x 0.2 0.20 0.90
M 1.2 x 0.2 0.20 1.00
M 1.4 x 0.2 0.20 1.20
M 1.6 x 0.2 0.20 1.40
M 1.8 x 0.2 0.20 1.60
M 2 x 0.25 0.25 1.75
M 2.2 x 0.25 0.25 1.95
M 2.5 x 0.35 0.35 2.10
M 3 x 0.35 0.35 2.60
M 3.5 x 0.35 0.35 3.10
M 4 x 0.5 0.50 3.50
M 4.5 x 0.5 0.50 4.00
M 5 x 0.5 0.50 4.50
M 5.5 x 0.5 0.50 5.00
M 6 x 0.75 0.75 5.20 20.1
M 7 x 0.75 0.75 6.20
M 8 x 0.75 0.75 7.20
M 8 x 1.0 1.00 7.00 39.2
M 9 x 0.75 0.75 8.20
M 9 x 1 1.00 8.00
M 10 x 0.75 0.75 9.20
M 10 x 1 1.00 9.00 64.5
M 10 x 1.25 1.25 8.80 61.2
M 11 x 0.75 0.75 10.20
M 11 x 1 1.00 10.00
M 12 x 1 1.00 11.00
M 12 x 1.25 1.25 10.80 92.1
M 12 x 1.5 1.50 10.50 88.1
M 14 x 1.0 1.00 13.00
M 14 x 1.25 1.25 12.80
M 14 x 1.5 1.50 12.50
M 15 x 1 1.00 14.00
M 15 x 1.5 1.50 13.50
M 16 x 1 1.00 15.00 178
M 16 x 1.5 1.50 14.50 167
M 17 x 1.0 1.00 16.00
M 17 x 1.5 1.50 15.50
M 18 x 1.0 1.00 17.00
M 18 x 1.5 1.50 16.50
M 18 x 2.0 2.00 16.00
M 20 x 1.0 1.00 19.00
M 20 x 1.5 1.50 18.50 272
M 20 x 2.0 2.00 18.00 258
M 22 x 1.0 1.00 21.00
M 22 x 1.5 1.50 20.50
M 22 x 2.0 2.00 20.00
M 24 x 1.0 1.00 23.00
M 24 x 1.5 1.50 22.50 401
M 24 x 2.0 2.00 22.00 384
M 25 x 1.0 1.00 24.00
M 25 x 1.5 1.50 23.50
M 25 x 2.0 2.00 23.00
M 27 x 1.0 1.00 26.00
M 27 x 1.5 1.50 25.50
M 27 x 2.0 2.00 25.00
M 28 x 1.0 1.00 27.00
M 28 x 1.5 1.50 26.50
M 28 x 2.0 2.00 26.00
M 30 x 1.0 1.00 29.00
M 30 x 1.5 1.50 28.50
M 30 x 2.0 2.00 28.00 621
M 30 x 3.0 3.00 27.00 581
M 32 x 1.5 1.50 30.50
M 32 x 2.0 2.00 30.00
M 33 x 1.5 1.50 31.50
M 33 x 2.0 2.00 31.00
M 33 x 3.0 3.00 30.00
M 35 x 1.5 1.50 33.50
M 35 x 2.0 2.00 33.00
M 36 x 1.5 1.50 34.50
M 36 x 2.0 2.00 34.00 915
M 36 x 3.0 3.00 33.00 865
M 39 x 1.5 1.50 37.50
M 39 x 2.0 2.00 37.00
M 39 x 3.0 3.00 36.00
M 40 x 1.5 1.50 38.50
M 40 x 2.0 2.00 38.00
M 40 x 3.0 3.00 37.00
M 42 x 1.5 1.50 40.50
M 42 x 2.0 2.00 40.00
M 42 x 3.0 3.00 39.00 1210
M 42 x 4.0 4.00 38.00 1150
M 45 x 1.5 1.50 43.50
M 45 x 2.0 2.00 43.00
M 45 x 3.0 3.00 42.00
M 45 x 4.0 4.00 41.00
M 48 x 1.5 1.50 46.50
M 48 x 2.0 2.00 46.00
M 48 x 3.0 3.00 45.00 1600
M 48 x 4.0 4.00 44.00 1540
M 50 x 1.5 1.50 48.50
M 50 x 2.0 2.00 48.00
M 50 x 3.0 3.00 47.00
M 52 x 1.5 1.50 50.50
M 52 x 2.0 2.00 50.00
M 52 x 3.0 3.00 49.00
M 52 x 4.0 4.00 48.00
M 55 x 1.5 1.50 53.50
M 55 x 2.0 2.00 53.00
M 55 x 3.0 3.00 52.00
M 55 x 4.0 4.00 51.00
M 56 x 1.5 1.50 54.50
M 56 x 2.0 2.00 54.00
M 56 x 3.0 3.00 53.00
M 56 x 4.0 4.00 52.00
M 58 x 1.5 1.50 56.50
M 58 x 2.0 2.00 56.00
M 58 x 3.0 3.00 55.00
M 58 x 4.0 4.00 54.00
M 60 x 1.5 1.50 58.50
M 60 x 2.0 2.00 58.00
M 60 x 3.0 3.00 57.00
M 60 x 4.0 4.00 56.00
M 62 x 1.5 1.50 60.50
M 62 x 2.0 2.00 60.00
M 62 x 3.0 3.00 59.00
M 62 x 4.0 4.00 58.00
M 64 x 1.5 1.50 62.50
M 64 x 2.0 2.00 62.00
M 64 x 3.0 3.00 61.00
M 64 x 4.0 4.00 60.00
M 65 x 1.5 1.50 63.50
M 65 x 2.0 2.00 63.00
M 65 x 3.0 3.00 62.00
M 65 x 4.0 4.00 61.00
M 68 x 1.5 1.50 66.50
M 68 x 2.0 2.00 66.00
M 68 x 3.0 3.00 65.00
M 68 x 4.0 4.00 64.00
M 70 x 1.5 1.50 68.50
M 70 x 2.0 2.00 68.00
M 70 x 3.0 3.00 67.00
M 70 x 4.0 4.00 66.00
M 70 x 6.0 6.00 64.00
M 72 x 1.5 1.50 70.50
M 72 x 2.0 2.00 70.00
M 72 x 3.0 3.00 69.00
M 72 x 4.0 4.00 68.00
M 72 x 6.0 6.00 66.00
M 75 x 1.5 1.50 73.50
M 75 x 2.0 2.00 73.00
M 75 x 3.0 3.00 72.00
M 75 x 4.0 4.00 71.00
M 75 x 6.0 6.00 69.00
M 76 x 1.5 1.50 74.50
M 76 x 2.0 2.00 74.00
M 76 x 3.0 3.00 73.00
M 76 x 4.0 4.00 72.00
M 76 x 6.0 6.00 70.00
M 80 x 1.5 1.50 78.50
M 80 x 2.0 2.00 78.00
M 80 x 3.0 3.00 77.00
M 80 x 4.0 4.00 76.00
M 80 x 6.0 6.00 74.00
M 85 x 2.0 2.00 83.00
M 85 x 3.0 3.00 82.00
M 85 x 4.0 4.00 81.00
M 85 x 6.0 6.00 79.00
M 90 x 2.0 2.00 88.00
M 90 x 3.0 3.00 87.00
M 90 x 4.0 4.00 86.00
M 90 x 6.0 6.00 84.00
M 95 x 2.0 2.00 93.00
M 95 x 3.0 3.00 92.00
M 95 x 4.0 4.00 91.00
M 95 x 6.0 6.00 89.00
M 100 x 2.0 2.00 98.00
M 100 x 3.0 3.00 97.00
M 100 x 4.0 4.00 96.00
M 100 x 6.0 6.00 94.00
Related ISO Standards
  • ISO 68:1973 ISO general purpose screw threads - Basic profile
  • ISO 261:1973 ISO general purpose metric screw threads - General plan
  • ISO 262:1973 ISO general purpose metric screw threads - Selected sizes for screws, bolts and nuts
  • ISO 724:1993 ISO general-purpose metric screw threads - Basic dimensions
  • ISO 965-1:1980 ISO general purpose metric screw threads - Tolerances - Part 1: Principles and basic data
  • ISO 965-2:1980 ISO general purpose metric screw threads - Tolerances - Part 2: Limits of sizes for general purpose bolt and nut threads - Medium quality
  • ISO 965-3:1980 ISO general purpose metric screw threads - Tolerances - Part 3: Deviations for constructional threads
  • ISO 1502:1996 ISO general-purpose metric screw threads - Gauges and gauging
Threads produced to this standard are interchangeable with threads produced to the metric standard ANSI/ASME B1.13M Metric Screw Threads: M Profile.
Miscellaneous
Threads
Thread data - metric, unified, ACME and others.
ANSI B1.20.1 - NPS - American National Standard Straight Pipe Threads
NPS pressure tight straight pipe threads with lubricant or sealer.
ANSI B1.20.1 - NPT - American National Standard Taper Pipe Threads
NPT and NPTF pipe threads - dimensions according ANSI/ASME B1.20.1/3.
ANSI/ASME B1.5 - ACME Screw Threads
Acme trapezoidal threads.
BS 21 - Pressure Tight Pipe Thread Joints
BSPT - British Standard Pipe Taper threads & BSP or BSPF - British Standard Pipe Parallel (Straight) threads.
EN 10226 - Pipe Threads where pressure tight joints are made on the threads - Dimensions
Pipe threads where pressure tight joints are made on the threads - Part 1: Taper external threads and parallel internal threads.
ISO - Pipe, Tube and Fittings Standards and Specifications
International Organization for Standardization - ISO - pipe, tube and fittings standards and specifications.
ISO 228 - Pipe Threads where Pressure Tight Joints are not made on the Threads
Requirements for thread form, dimensions, tolerances and designation for fastening pipe threads, thread sizes.
ISO 2841 - Spark Plugs Metric Threads
Metric threads spark plugs according ISO 28741.
ISO 2901 - Metric Trapezoidal Screw Threads
Dimensions of ISO metric trapezoidal screw threads.
ISO 7 - Pipe Threads where Pressure-tight Joints are made on the Threads
Pressure-tight joints made on the pipe threads.
Metric Bolt Heads and Wrench Sizes
ANSI/SO, DIN and JIS bolts.
Metric Bolts - Minimum Ultimate Tensile and Proof Loads
Metric Bolts - Tightening Torques
Metric Threads - Clearance Holes and Tapping Drill Sizes
Recommended clearance holes and drill tap sizes.
NPT Threads - Taps and Drill Sizes
NPT - Briggs Standard Pipe threads - Taps and Drill Sizes.
Reduced Torque with Lubricated Bolts
Standards Applied for Piping Threads
Applied threaded standards used for piping connections.
Steel Bolts - ASTM Grades
Steel Bolts - SAE Grades
T-Slots and T-Nuts - Metric Sizes
Standard metric T-slots and T-nuts.
Threaded Bolts - Stress Area
Threaded bolts tensile stress area.
Threaded Rods - Loads in Imperial Units
Weight rating of threaded hanger rods.
Threads commonly used in Piping
Piping thread standards.
UNC and UNF - Unified Inch Screw Threads
US and Metric Fasteners - Thread Sizes
Printable fastener chart.
US Bolts - Tensile Strength and Proof Loads
US Hex Bolts - Metric
US Wood Screws - Nominal Sizes
Wood screws - nominal sizes vs. diameters.
Whitworth Pipe Threads
BSPP (G) - British Standard Pipe Parallel and BSPT (R/Rp) – British Standard Tapered Pipe for pipes and tapered threads - G/R/Rp.
Withworth Threads - Taps and Drill Sizes
Taps and drill sizes used for Whitworth - ISO 7 and ISO 228 threads.
Wrench Spanners - Inches vs. mm
Convert between US Inches and metric mm wrench and spanner sizes.
