ISO 28741 Metric Thread Dimensions for Spark Plugs
Spark plug threads according ISO 28741  Road vehicles — Spark-plugs and  their cylinder head housings — Basic  characteristics and dimensions.
ISO 2841 - Spark Plugs Metric Threads
SizeMajor Diameter
(mm)
Minor Diameter1)
(mm)
Pitch
(mm)
Tap Drill
(mm)
Depth
(mm)
M10 x 1.0 10.0 9.153 - 8.917 1.00 9.20 65
M12 x 1.25 12.0 10.912 - 10.647 1.25 10.9 72
M14 x 1.25 14.0 12.912 - 12.647 1.25 12.90 72
M18 x 1.5 18.0 16.676 - 16.376 1.50 16.75 68
1) Tolerance class 6H.
The threads of spark-plugs and the corresponding tapped holes in the cylinder heads shall conform to ISO 68-1, ISO 261, ISO 965-1, and ISO 965-3 with thread angle 60o.
Mechanics
Threads
Thread data - metric, unified, ACME and others.
ANSI B1.20.1 - NPS - American National Standard Straight Pipe Threads
NPS pressure tight straight pipe threads with lubricant or sealer.
ANSI B1.20.1 - NPT - American National Standard Taper Pipe Threads
NPT and NPTF pipe threads - dimensions according ANSI/ASME B1.20.1/3.
BS 21 - Pressure Tight Pipe Thread Joints
BSPT - British Standard Pipe Taper threads & BSP or BSPF - British Standard Pipe Parallel (Straight) threads.
ISO 7 - Pipe Threads where Pressure-tight Joints are made on the Threads
Pressure-tight joints made on the pipe threads.
ISO 724 - Metric Threads
Piping Thread Standards
Applied threaded standards used for piping connections.
Threads commonly used in Piping
Piping thread standards.
U.S. and Metric Fasteners - Thread Sizes
Printable fastener chart.
Unified Thread Standards: UNC & UNF Size Charts & Specifications
