BS 21 - Pressure Tight Pipe Thread Joints
Threads according BSi - British Standard Institute - BS 21 "Specification for pipe threads for tubes and fittings where pressure-tight joints are made on the threads" can be made as
  • parallel (straight) threads
  • taper threads
Note that the BS 21 is withdrawn, superseded and replaced by BS EN 10226-1:2004, BS EN 10226-2:2005, BS EN 10226-3:2005. Product threads in ISO 7 and BS 21 and EN 10226 are identical and fully interchangeable.
Parallel (straight) Threads
BS parallel threads are also referred to as British Gas, British Pipe Parallel or Parallel Fastening Thread.
Common symbols used for the thread: BSP, BSPP, BSSPI, BSPF, BSPG, PS, Rp, G
The BSPP (parallel) male will mate with a BSPP (parallel) female or a female port.
Usually marked: G size ISO
Taper Threads
BS taper threads are also referred to as British Standard Taper Pipe, Pipe Taper or Conical Thread.
Common symbols used for the thread: BSPT, BSPTr, PT, KR, R, Rc
Usually marked: Rc size ISO
Characteristics of BSPT taper threads:
  • tapered thread 1o47'
  • truncation of roots and crests are rounded
  • 55o thread angle
  • pitch is measured in threads per inch
  • taper is 3/4" per foot or 1 in 16 on the diameter
Pipe Size
(inches)
Threads per Inch
TPI - Pitch
Major Diameter
OD
(inches)
Pitch
(mm)
Major Diameter
(mm)
Minor Diameter
(mm)
1/16" 28 0.304 0.907 7.723 6.561
1/8" 28 0.383 0.907 9.728 8.566
1/4" 19 0.518 1.337 13.157 11.445
3/8" 19 0.656 1.337 16.662 14.950
1/2" 14 0.825 1.814 20.955 18.631
5/8" 14 0.902 1.814 22.911 20.587
3/4" 14 1.041 1.814 26.441 24.117
7/8" 14 1.189 1.814 30.201 27.877
1" 11 1.309 2.309 33.249 30.291
1-1/8" 11 1.49 2.309 37.897 34.939
1-1/4" 11 1.650 2.309 41.910 38.952
1-1/2" 11 1.882 2.309 47.803 44.845
1-3/4" 11 2.116 2.309 53.746 50.788
2" 11 2.347 2.309 59.614 56.656
2-1/4" 11 2.587 2.309 65.710 62.752
2-1/2" 11 2.960 2.309 75.189 72.226
3" 11 3.460 2.309 87.844 84.926
  • 1 inch (in) = 25.4 millimeter (mm)
  • 1 millimeter (mm) = 0.03937 inch (in)
Reference standards for BS 21 tapered pipe threads are:
  • ISO 7/1
  • DIN 2999 - Germany
  • JIS B 0203 - Japan
Dimensions of Pipes and Tubes
Threads
Thread data - metric, unified, ACME and others.
ANSI B1.20.1 - NPS - American National Standard Straight Pipe Threads
NPS pressure tight straight pipe threads with lubricant or sealer.
ANSI B1.20.1 - NPT - American National Standard Taper Pipe Threads
NPT and NPTF pipe threads - dimensions according ANSI/ASME B1.20.1/3.
EN 10226 - Pipe Threads where pressure tight joints are made on the threads - Dimensions
Pipe threads where pressure tight joints are made on the threads - Part 1: Taper external threads and parallel internal threads.
ISO 228 - Pipe Threads where Pressure Tight Joints are not made on the Threads
Requirements for thread form, dimensions, tolerances and designation for fastening pipe threads, thread sizes.
ISO 28741 Metric Thread Dimensions for Spark Plugs
Metric threads spark plugs according ISO 28741.
ISO 7 - Pipe Threads where Pressure-tight Joints are made on the Threads
Pressure-tight joints made on the pipe threads.
ISO 724 - Metric Threads
Piping Thread Standards
Applied threaded standards used for piping connections.
Threads commonly used in Piping
Piping thread standards.
Unified Thread Standards: UNC & UNF Size Charts & Specifications
Whitworth Pipe Threads
BSPP (G) - British Standard Pipe Parallel and BSPT (R/Rp) – British Standard Tapered Pipe for pipes and tapered threads - G/R/Rp.
