Whitworth Pipe Threads
The Whitworth thread specifies a 55° thread angle and a thread depth of 0.640327p and a radius of 0.137329p where p is the pitch.
The most common types of Whitworth pipe threads are
In the UK metric ISO threads have replaced Withworth (BSW) and British Standard Fine (BSF) threads. In USA the most common threads are "Unified Fine" (UNF)  and "Unifed Coarse" (UNC).
BSPP (G) – British Standard Pipe Parallel
Thread size
(inch)
Major Diameter
(mm)
Minor Diameter
(mm)
TPI
G 1/16 7.723 6.561 28
G 1/8 9.728 8.566 28
G 1/4 13.157 11.445 19
G 3/8 16.662 14.950 19
G 1/2 20.955 18.631 14
G 3/4 26.441 24.117 14
G 1 33.249 30.291 11
G 2 59.614 56.656 11
  • TPI = threads per inch
BSPT (R/Rp) – British Standard Tapered Pipe
Male Thread size
(inch)
Female Thread size
(inch)
Major Diameter
(mm)
Minor Female Diameter
(mm)
TPI
R 1/16 Rp 1/16 7.723 6.490 28
R 1/8 Rp 1/8 9.728 8.495 28
R 1/4 Rp 1/4 13.157 11.341 19
R 3/8 Rp 3/8 16.662 14.846 19
R 1/2 Rp 1/2 20.955 18.489 14
R 3/4 Rp 3/4 26.441 23.975 14
R 1 Rp 1 33.249 30.111 11
R 2 Rp 2 59.614 56.476 11
  • BSPT male threads seal against threads of fixed BSPT female.
  • BSPT male and BSPP male with conical 30° seat seal against matching conical 30° seat of BSPP female swivel.
Threads
Thread data - metric, unified, ACME and others.
ANSI B1.20.1 - NPT - American National Standard Taper Pipe Threads
NPT and NPTF pipe threads - dimensions according ANSI/ASME B1.20.1/3.
British Standard Brass Threads
British Brass Thread is an imperial unit based screw thread.
British Standard Cycle Threads
British Standard Cycle is a British Imperial screw thread standard.
BS 21 - Pressure Tight Pipe Thread Joints
BSPT - British Standard Pipe Taper threads & BSP or BSPF - British Standard Pipe Parallel (Straight) threads.
EN 10226 - Pipe Threads where pressure tight joints are made on the threads - Dimensions
Pipe threads where pressure tight joints are made on the threads - Part 1: Taper external threads and parallel internal threads.
ISO 228 - Pipe Threads where Pressure Tight Joints are not made on the Threads
Requirements for thread form, dimensions, tolerances and designation for fastening pipe threads, thread sizes.
ISO 7 - Pipe Threads where Pressure-tight Joints are made on the Threads
Pressure-tight joints made on the pipe threads.
ISO 724 - Metric Threads
Piping Thread Standards
Applied threaded standards used for piping connections.
Threads commonly used in Piping
Piping thread standards.
Unified Thread Standards: UNC & UNF Size Charts & Specifications
