Piping Thread Standards
Straight Pipe Standards
NPSC - American Standard Straight Pipe Threads in Pipe Couplings
Applicable Standards
- ANSI B1.20.1 PIPE THREADS, GENERAL PURPOSE (INCH)
- FED-STD-H28/7 SCREW-THREAD STANDARDS FOR FEDERAL SERVICES SECTION 7 PIPE THREADS - GENERAL PURPOSE
NPSF - Dryseal American Standard Fuel Internal Straight Pipe Threads
- SAE J476 DRYSEAL PIPE THREADS
- ANSI B1.20.3 DRYSEAL PIPE THREADS (INCH)
- FED-STD-H28/8 SCREW-THREAD STANDARDS FOR FEDERAL SERVICES SECTION 8 DRYSEAL PIPE THREADS
NPSI - Dryseal American Intermediate Internal Straight Pipe Threads
NPSM - American Standard Straight Pipe Threads for Free-Fitting Mechanical Joints for Fixtures (these threads fit freely over NPTF threads. They are used in swivel nuts of 07 adapters)
Taper Pipe Standards
ANPT - Aeronautical National Taper Pipe Threads
- MIL-P-7105 PIPE THREADS, TAPER, AERONAUTICAL NATIONAL FORM, SYMBOL ANPT, GENERAL REQUIREMENTS
NPT - American Standard Taper Pipe Threads for General Use
NPTF - Dryseal American Standard Taper Pipe Threads
PTF - SAE Short - Dryseal SAE Short Taper Pipe Threads
PTF - SAE Short is mainly used in low pressure pneumatic and fuel applications.
PTF SPL Short & SPL Extra Short - Dryseal Special Short Taper Pipe Threads
Are used in some pneumatic components where shortened thread depth is required because of size limitations.
AWWA - American Water Works Association
- ANSI/AWWA C800-05 UNDERGROUND SERVICE LINE VALVES AND FITTINGS
Unified Thread Standards
UN - Unified Constant Pitch Threads (standard series: 4, 6, 8, 12, 16, 20, 28, 32)
- ASME B1.1 UNIFIED INCH SCREW THREADS (UN & UNR THREAD FORM)
FED-STD-H28/2 SCREW-THREAD STANDARDS FOR FEDERAL SERVICES SECTION 2 UNIFIED INCH SCREW THREADS-UN AND UNR THREAD FORMS
UNC - Unified Coarse Threads
- FED-STD-H28/2 SCREW-THREAD STANDARDS FOR FEDERAL SERVICES SECTION 2 UNIFIED INCH SCREW THREADS-UN AND UNR THREAD FORMS
UNEF - Unifed Extra Fine Threads
UNF - Unified Fine Threads
UNS - Unified Special Pitch Threads
- SCREW-THREAD STANDARDS FOR FEDERAL SERVICES-SEC. 3
UNJ - Unified Controlled Root Radius Threads
- ANSI B1.15 UNIFIED INCH SCREW THREADS (UNJ THREAD FORM)
- FED-STD-H28/4 SCREW-THREAD STANDARDS FOR FEDERAL SERVICES SECTION 4 CONTROLLED RADIUS ROOT SCREW THREADS, UNJ SYMBOL
Metric Thread Standards
M - Metric Screw Threads M profile
- ISO 261 ISO GENERAL PURPOSE METRIC SCREW THREADS - GENERAL PLAN
- ASME B1.13M METRIC SCREW THREADS: M PROFILE
- FED-STD-H28/21 METRIC SCREW-THREADS
M Keg Metric Taper Threads
Mainly used in Germany.
- DIN 158-1 METRIC EXTERNAL TAPER SCREW THREADS AND MATING INTERNAL PARALLEL SCREW THREADS - PART 1. NOMINAL SIZES, LIMIT DEVIATIONS, LIMITS OF SIZE AND VERIFICATION
- DIN 158-2 METRIC EXTERNAL TAPER SCREW THREAD AND MATING INTERNAL PARALLEL SCREW THREADS - PART 2. GAUGING SYSTEM, USE OF GAUGES, CALCULATION OF GAUGE DIMENSIONS AND GENERAL FEATURES
BSi - British Standards
R (BSPT) - British Standard Taper Pipe Threads, External
- BS 21 PIPE THREADS FOR TUBES AND FITTINGS WHERE PRESSURE-TIGHT JOINTS ARE MADE ON THE THREADS (METRIC DIMENSIONS) (withdrawn)
- ISO 7 PIPE THREADS: DESIGNATION, DIMENSIONS/TOLERANCES
Rc (BSPT) - British Standard Taper Pipe Threads, Internal
Rp or G (BSPP) - British Standard Pipe (Parallel) Threads
- BS 2779 PIPE THREADS FOR TUBES & FITTINGS WHERE PRESSURE-TIGHT JOINTS ARE NOT MADE ON THE THREADS (METRIC DIMENSIONS) (withdrawn)
- ISO 228 PIPE THREADS PT 1: DESIGNATION, DIMENSIONS, TOLERANCE
Japanese Standards
PF - JIS Parallel Pipe Threads
PF threads are functionally interchangeable with BSPP. This is an old designations replaced with G.
- JIS B 202 PARALLEL PIPE THREADS
PT - JIS Taper Pipe Threads
PT threads are functionally interchangeable with BSPT threads. This is an old designations replaced with and R and Rc.
- JIS B 0203 TAPER PIPE THREADS
PS - JIS Parallel Internal Pipe Threads (to mate with PT threads)
More about pipe thread standards.
• Threads
Thread data - metric, unified, ACME and others.
ANSI B1.20.1 - NPS - American National Standard Straight Pipe Threads
NPS pressure tight straight pipe threads with lubricant or sealer.
ANSI B1.20.1 - NPT - American National Standard Taper Pipe Threads
NPT and NPTF pipe threads - dimensions according ANSI/ASME B1.20.1/3.
British Standard Brass Threads
British Brass Thread is an imperial unit based screw thread.
British Standard Cycle Threads
British Standard Cycle is a British Imperial screw thread standard.
BS 21 - Pressure Tight Pipe Thread Joints
BSPT - British Standard Pipe Taper threads & BSP or BSPF - British Standard Pipe Parallel (Straight) threads.
EN 10226 - Pipe Threads where pressure tight joints are made on the threads - Dimensions
Pipe threads where pressure tight joints are made on the threads - Part 1: Taper external threads and parallel internal threads.
ISO 228 - Pipe Threads where Pressure Tight Joints are not made on the Threads
Requirements for thread form, dimensions, tolerances and designation for fastening pipe threads, thread sizes.
ISO 28741 Metric Thread Dimensions for Spark Plugs
Metric threads spark plugs according ISO 28741.
ISO 7 - Pipe Threads where Pressure-tight Joints are made on the Threads
Pressure-tight joints made on the pipe threads.
ISO 724 - Metric Threads
NPT Threads - Taps and Drill Sizes
NPT - Briggs Standard Pipe threads - Taps and Drill Sizes.
Threads commonly used in Piping
Piping thread standards.
UNS - Unified Numbering System
The Unified Numbering System - UNS - used for metals and alloys.
Whitworth Pipe Threads
BSPP (G) - British Standard Pipe Parallel and BSPT (R/Rp) – British Standard Tapered Pipe for pipes and tapered threads - G/R/Rp.
Withworth Threads - Taps and Drill Sizes
Taps and drill sizes used for Whitworth - ISO 7 and ISO 228 threads.
