In order to seal the conical external thread connects with the cylindrical mother screw. The connection don't guarantees sealing - so a sealant should be used.
Thread data - metric, unified, ACME and others.
NPS pressure tight straight pipe threads with lubricant or sealer.
NPT and NPTF pipe threads - dimensions according ANSI/ASME B1.20.1/3.
BSPT - British Standard Pipe Taper threads & BSP or BSPF - British Standard Pipe Parallel (Straight) threads.
Requirements for thread form, dimensions, tolerances and designation for fastening pipe threads, thread sizes.
Pressure-tight joints made on the pipe threads.
Applied threaded standards used for piping connections.
Piping thread standards.
BSPP (G) - British Standard Pipe Parallel and BSPT (R/Rp) – British Standard Tapered Pipe for pipes and tapered threads - G/R/Rp.
