NPT Threads - Taps and Drill Sizes
The NPT - National Pipe Taper Threads - is based on the Briggs Standard Pipe Thread.
Drill sizes for Briggs Standard Pipe taps for direct tapping without reaming are indicated below:
Size Taps
(inches)
TPISize Drill
(inches)
1/8 27 21/64
1/4 18 27/64
3/8 18 9/16
1/2 14 11/16
3/4 14 29/32
1 11.5 1 1/8
1 1/4 11.5 1 15/32
1 1/2 11.5 1 23/32
2 11.5 2 3/16
2 1/2 8 2 9/16
3 8 3 3/16
3 1/2 8 3 11/16
4 8 4 3/16
  • TPI = threads per inch
  • 1 inch = 25.4 mm
Dimensions of Pipes and Tubes
Threads
Thread data - metric, unified, ACME and others.
ANSI B1.20.1 - NPS - American National Standard Straight Pipe Threads
NPS pressure tight straight pipe threads with lubricant or sealer.
ANSI B1.20.1 - NPT - American National Standard Taper Pipe Threads
NPT and NPTF pipe threads - dimensions according ANSI/ASME B1.20.1/3.
ISO 7 - Pipe Threads where Pressure-tight Joints are made on the Threads
Pressure-tight joints made on the pipe threads.
ISO 724 - Metric Threads
Metric Threads - Clearance Holes and Tapping Drill Sizes
Recommended clearance holes and drill tap sizes.
Piping Thread Standards
Applied threaded standards used for piping connections.
Threads commonly used in Piping
Piping thread standards.
Withworth Threads - Taps and Drill Sizes
Taps and drill sizes used for Whitworth - ISO 7 and ISO 228 threads.
