Nominal Diameter
(mm)
Thread data - metric, unified, ACME and others.
ANSI/SO, DIN and JIS bolts.
NPT - Briggs Standard Pipe threads - Taps and Drill Sizes.
Metric versus Imperial equivalent screw dimensions.
Hard wood and soft wood pilot holes, shank clearance holes and countersink diameters.
Taps and drill sizes used for Whitworth - ISO 7 and ISO 228 threads.
Allowable withdrawal load force.
